Home > Technical (L405) > TPMS Problems
Looping111
Switzerland 2014 Range Rover Autobiography SDV8 Luxor
TPMS Problems
Since I have changed my wheels in spring (I have to set of rims with sensors) I had a error on the tire pressure system. My tyre-dealer checked the sensors and found out that 2 of them are dead. OK after 10 years. Before 3 weeks I changed again the wheels with new tires and new sensors. Sensors where programmed to the module.
But the system don't reset automatically. After programming we wait 20 min. Then drive half hour with about 100 km/h. NO success... Still the error message.
I have tried to disconnect the battery for 10 min. After starting the error was not there and I could see in the service menue all wheel pressures how should be. Perfect ? No? After arround 20 min. driving I got again the error. (interesting the 20 min normally is the time to relearn the system.. in my case it is exactly the opposite)
Before I start to replace the control module (which is located under the roof cover, what is a big sh.. to replace ) I want to ask if someone has other idea what to do ?
It is a RR l405 autobiographic 2014 SDV8
Greetings from Switzerland
Post #701954 11th Oct 2024 8:29am
i suspect the replacement tpms were not activated [switched on] ...there is a tool that will do this ... ... - .- -.
Post #701962 11th Oct 2024 10:17am
Bora20
Canada 2013 Range Rover 5.0 SC V8 Santorini Black
There are also two different frequency TPMS. Aftermarket units are typically dual frequency. I suspect like Stan said they weren’t activated and/or updated with the car. I have the $400 🇨🇦 tool to do this at home. Takes less than five minutes to activate and connect them to the car through the OBDII port. Dan. 🇨🇦 2013 L405 5.0 SCV8
Post #701984 11th Oct 2024 2:18pm
Looping111
The sensors where cloned with the ID of the old ones and all where programmed to the system. The programming unit reports that all was successfull. It was possible to read them out with the tester. When I disconnect the battery 10 min. after restart the car the error was cleared and I could view all tyre pressures in the service menu. So I understand that the sensors are activated and work. But after 20min. the error comes again....therfore I am not shure if the control unit itself is the problem ??
Post #701987 11th Oct 2024 2:32pm
Looping111
Today I checked the voltage of the battery, but in the front at the plugs for remote start. Only 11.6V, but there is maybe a drain .. So this evening I will check direct at the batteries under the spere...
Could it be, that my TPMS Problems come from old battery ? Is that control unit sensitive on voltage ?
Post #702905 23rd Oct 2024 11:12am
