![]() | Home > Maintenance & Mods (L322) > Another rangerover |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
Re the towbar, yes those brackets need removing, which means removing the rear bumper and the crash bar underneath (4 nuts each side inside the boot compartment - you need to remove some of the plastic trim to access them). Then the full towbar assembly can be fitted in their place. The exhaust needs supporting temporarily whilst you do this. Recommend carefully sealing the crash bar where the 8 fixed bolts pass through the bodywork, as it’s a classic place for water ingress into the boot well. I’ve used Tiger Seal previously. Jonathan
JT Member Since: 28 Nov 2016 Location: Hailsham. East Sussex Posts: 39 ![]() ![]() ![]() |
Thanks for the advice. Thought that would be case after looking at various drawbars 👍 now I know what to buy. Cheers John |
Hi. Replaced Bluetooth module today so got fibre optic completing circuit. So red light coming from front of vehicle and leaving back area but still only Land Rover logo. Will try hard reset as all fuses in rear right and glove box ok. Any other suggestions?! Will keep you posted. Cheers 🍻 |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 862 ![]() ![]() ![]() |
remove fuse 49 in the glove box for 5 mins, then replace - this often gets you back the Audio and SatNav menus etc |
Will try that as reset didn’t work although managed to get into screen menu following other advice from a member. Touch middle of screen for 5 seconds then nav button for 5 but could access radio , sat nav settings but could not get anything to work ( could not set time ) now went out today and drove 3 hours to a friends function got in it tonight to come home. And had a flat battery jump started and drove home with lights on heater etc stopped when I got home and turned off. Started it with no problem. Will see if it starts tomorrow. |
