![]() | Home > Technical (L405) > I'm now a Regeneration trainee nerd--lol |
SootScout Member Since: 08 Oct 2024 Location: London Posts: 1 ![]() ![]() |
Hi all,
In contrast, here is another trip recorded on the German Autobahn with speeds well exceeding 80 mph. Interestingly, the DPF is working as designed here.
Could this mean that the "faulty" DPFs were designed to be used outside the UK, where speed limits are higher...? You can explore the data further on the website. If you are affected by the same issue, I hope you find the information on the site useful. Cheers |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1310 ![]() ![]() |
The whole idea of DPF regeneration is explained in the WS manual below, and your first graph shows passive regeneration over 250C at limited events not easy to achieve constant PRegen below 70mph. As soot load/mileage increases, you meet the trigger point for an active Regeneration, which could be average mileage of your ARegens or grams of soot limit is achieved.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1454 ![]() ![]() |
I'd be more concerned about what the current DPF soot level is, and whether a regen actually brings that level down as its meant to. Thats what matters at any particular time.
100% with fisha
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1657 ![]() ![]() ![]() |
@Philip,
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2615 ![]() ![]() |
Never looked at live data before, but it smelled very hot underneath when I parked earlier and I wondered if I might have interrupted a regen.
I have the Autel AP200 and only use if for code reading and resetting etc, I never use it for monitoring live regen data.
Am I missing something here? Ignoring advice? Texting? |
Has anyone seen this? Tried “Mirror Mode”?
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 218 ![]() ![]() ![]() |
This has got to be one of the most informative and fascinating (how sad am I?) threads I have followed for a long while. I am all setup and actively monitoring but I do have a couple of little questions just to be clear in my own mind;
Abacus405 Member Since: 01 Feb 2022 Location: West yorkshire Posts: 108 ![]() ![]() ![]() |
1) I monitor most of the time, mine always regenerates at 25g of soot. But the other day whilst out on a drive it regenerated at 19g. No idea why, but if I wasn’t watching I might have turned the engine off and failed a regen.
My 2p |
