![]() | Home > Technical (L405) > GAP IID G3 Throwing Errors |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6748 ![]() ![]() ![]() |
Do the errors stop when you remove the IID tool? Got - 2017 SDV8 Autobiography in Loire Blue
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 217 ![]() ![]() ![]() |
Any chance the ODB port has been switch out? I know that it is possible to change the ODB port, effectively rewire it, and require an adapter to plug into it. It is another security measure that can be implemented. Only came to mind as you say you have a Ghost 2 fitted so unless you had it fitted maybe the previous owner went for extra security? Long shot I know but I cant think of any reason why a GAP tool would do what you are seeing. _______________________________________________
Shadow_Dancer Member Since: 06 May 2024 Location: Essex Posts: 30 ![]() ![]() |
First time the whole Speedo cluster just went black. I had to switch the car off and wait a few secs to turn back on and it came back but with a bunch of errors. I removed the gap tool and turned it off and on, entered ghost sequence and it returned to normal except engine management light stayed on. Tried again and as soon as I entered the tool it threw more errors but didn’t turn off the screen this time but car would not start. |
It’s possible based on how the car is reacting when I put the tool in the port. However a garage recently plugged in their diagnostic tool and it worked fine. If there was some kind of switch out would their one not have worked also? I emailed GAP but their responses are pretty terrible. Mostly one liners and not very helpful. See one below “its either defective or the OBD pins are not tight enough even if they look tight” |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1293 ![]() ![]() |
Get a Autel AP200 they are good and cheap and will certainly be proof that the GAP tool is ill or not. 2018 SE SDV8 4.4 Byron Blue |
Thank you Kot, I’ll give that a go |
Dont buy from amazon/fleabay
I always plug mine in with the ignition off Got - 2017 SDV8 Autobiography in Loire Blue
I do also, then ignition on, but engine off to do checks. 2018 SE SDV8 4.4 Byron Blue |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35540 ![]() ![]() |
i fear this 'might' be user error....
all the pins on the gap iid tool are dead straight. I have tried to re-insert multiple times. I tried inserting with car fully off and search but would not detect tool.
can you try the tool on another landrover vehicle?
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1796 ![]() ![]() |
We see this on occasion. Dash lights up like a Christmas tree when you plug the tool in
