![]() | Home > Maintenance & Mods (L405) > Blue screen of death on reverse camera L405 |
JDGeorgia Member Since: 11 Oct 2023 Location: Atlanta GA Posts: 160 ![]() ![]() ![]() |
If everything else seems OK - I would think it was the camera.
Silverstone Member Since: 30 May 2024 Location: Silverstone Posts: 31 ![]() ![]() ![]() |
Are the parking sensors working? "There is no replacement for displacement" - W O Bentley |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1465 ![]() ![]() ![]() |
Thanks CHaps,
Right so I now bitten the bullet and have a replacement camera, now my next question is how does one get access to remove the little blighter please?
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 300 ![]() ![]() ![]() |
Here you go, very easy job, just prise the finishing strip away from the tailgate, see the link below:-
Many thanks 4RRS,
minim Member Since: 15 Mar 2024 Location: Bergen Posts: 36 ![]() ![]() ![]() |
My camera was full of water/corrosion when this happened. The instructions above doesn't apply for the 360 version BTW. I removed the inner trim and pulled the camera from the inside.
Before you plug the new camera in, just double check they are identical as there are 4 pin and 6 pin connector types, not sure of the model year when they changed. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Thanks for the advice, I have been told I need part number 52029 which is a 6 pin, I shall find out tomorrow.
I have the 360 surround system on both my L405 SVA & L494 and have removed both from the outside as per the document. Give it a go, I'm sure you'll be fine. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Perfect sounds like a plan.
6 pin should be correct, just checked and they changed at GA chasis number (2016) to the hi definition camera and before 2013 they were 4 pin with a coax connection, ended up changing those 3 times on the Mrs's Evoque many years ago. Seems they always fail through water ingress. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Fingers crossed then, I will report back once done.
Sounds right. It's easier than accessing from the outside imho. The strip outside you need to be careful with as the plastic get old and brittle. Be gentle where it's really thin so you don't Crack it. I have removed it before when I was spraying my rear door and I'd do it from the inside now that I've tried both ways. You just pop the cover off inside and wiggle loose a module that blocks the camera. Use needle nose pliers to unhook it from the plastic and it's out. Doing the outside route risk damaging your paint and cracking the trim. There is a YouTube video explaining it. ?si=8LcfVKGFGyQw9NKO |
