Home > Technical (L405) > Are there any trailer/tow module fuses?
garyRR
Something weird happened yesterday - I plugged my trailer in and as I was plugging it in, the side markers flashed on (as the engine was running) and then off, and now they won't come on.
Obviously I will check the trailer plug for any loose wires or corroded terminals, but because the lights did flash on and then disappeared, it makes me wonder if there is a fuse for the trailer side lights in the car?
Does anyone have a fuse box diagram and description of fuses for the rear fuse box? 2015 Range Rover Autobiography 4.4 SDV8
Post #701600 6th Oct 2024 9:47am
[Incorrect link removed] Thumbs Up
Though despite that being what TOPIX says, I have one that I suspect might be tow electrics on the side to the right of the main fuse box in the boot - otherwise I have no idea what it's for....
Post #701603 6th Oct 2024 9:53am
garyRR
Thanks Alistair. Let me check the fuses. I see several on the diagram for trailer side lights. As my trailer has side markers all the way down, plus front and rear, and I think both L and R are wired to the same pin, it may just be on the edge of the limit of the fuse. 2015 Range Rover Autobiography 4.4 SDV8
Post #701606 6th Oct 2024 10:21am
Sorry - I'm not sure the Topix link is correct - despite what Google says - those pictures don't look like an L405 Embarassed
Post #701609 6th Oct 2024 10:31am
As penance, I went out and checked my owners manual Laughing
Passenger Fuse box - fuse 27 - 10A - trailer side lamps Thumbs Up
Post #701612 6th Oct 2024 10:45am
garyRR
Many thanks for looking in your book Alistair. Fuse 27 had indeed blown. Swapped it out and all working again. 2015 Range Rover Autobiography 4.4 SDV8
Post #701711 7th Oct 2024 5:31pm
Happy to help - glad it was an easy fix Cool
Post #701727 7th Oct 2024 7:49pm
