![]() | Home > Maintenance & Mods (L405) > Dynamic Responce Fluid |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
Well I looked at the reservoir when I was changing the headlight and as far as I could tell there was none in so I bought some and topped it up (book says risk of damage if you drive it below min). However I suspect it is now overfilled but as the fluid is pretty light I can’t tell, it still doesn’t show up against the min and max marks on the reservoir. What damage (if any) will overfilling do. Even using a torch to backlight I still couldn’t see the level of fluid in the reservoir. So any ideas how I might see the fluid level and does it cause a problem if overfilled. Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
I don't think a little extra will hurt, I found the best way was to shine the torch directly in the top, you can then see if it is around the min and max mark, if there is loads extra nick the wifes turkey baster and suck some out... |
Took a bit out with the turkey baster and washed it thoroughly. But come Christmas SWMBO will notice but I’ll blame Pete |
I have broad shoulders... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
Brilliant. ^^^
onetwentie Member Since: 28 Oct 2024 Location: West Yorkshire Posts: 5 ![]() ![]() ![]() |
Hey all my first post on this forum. So having owned my 2013 RRS L405 for a month or two, the first issue I have ran into is as OP mentioned the low ACE fluid.
Workshop manual download link is in our wiki... ... - .- -.
Thanks Stan - yes found it soon after as I was trawling the Wiki.
Some info here...
And here…
It's certainly a "when" rather than "if" |
