Home > Maintenance & Mods (L322) > Coolant in Motor L322 Supercharged 5.0 V8 2010
PhilWa
United Kingdom 2010 Range Rover Supercharged Supercharged Java Black
Hi, I put 1l of coolant instead of oil into my motor. I wanted to top it up and took the wrong grey canister. I did not start the engine. What shall I do?
Post #701076 29th Sep 2024 2:03pm
dingg1
Get yer arse down the road and buy an oil filter and enough oil for an oil change.
What else would you do?
Post #701078 29th Sep 2024 2:29pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
And do not not touch the starting button! Get out the oil/coolant mix with a vacum pump, refil and then do an oil change thrue the drain plug. Relative of mine ruined his engine by running it to the Indie after he did the same mistake as you.
Post #701083 29th Sep 2024 3:52pm
PhilWa
Sorted! Thanks for the messages and motivation to do it myself
Post #701288 2nd Oct 2024 2:09pm
