![]() | Home > Maintenance & Mods (L322) > Coolant in Motor L322 Supercharged 5.0 V8 2010 |
PhilWa Member Since: 10 Sep 2024 Location: Hale Posts: 5 ![]() ![]() ![]() |
Hi, I put 1l of coolant instead of oil into my motor. I wanted to top it up and took the wrong grey canister. I did not start the engine. What shall I do? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
Get yer arse down the road and buy an oil filter and enough oil for an oil change.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
And do not not touch the starting button! Get out the oil/coolant mix with a vacum pump, refil and then do an oil change thrue the drain plug. Relative of mine ruined his engine by running it to the Indie after he did the same mistake as you. |
Sorted! Thanks for the messages and motivation to do it myself |
