![]() | Home > General (L405) > confused...... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
It's always been possible to have a 'better' spec on a 'lower' model - depending on what feature it is that you're looking for.....
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 502 ![]() ![]() ![]() |
and throw into the equation that in the 2020 to 2022 period, the covid issues of getting the correct componets was an issue so you are best looking at the car itself, in person and going through a checklist of what you want compared to what is fitted.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2672 ![]() ![]() ![]() |
Noticed this when looking for mine , westminsters are traditionally run out models . Noticed that loads have the additional roof speakers in the front but not the full signature system , clearly getting rid of parts . As others have said , only way to tell is to see the build sheet for what they have. |
DaveBL405 Member Since: 26 Sep 2024 Location: Hampshire Posts: 27 ![]() ![]() ![]() |
I would second this - I've just bought a 2021 D300 AB but had to search for ages to find the spec and milage that I wanted. I hadn't noticed much in the way of COVID impact, though I'm sure there was some differences. You can get the dealer to source the build sheet for you so you can check off precisely what was on the car's build - rather than relying on the dealer description which can sometimes be a bit inprecise! |
