![]() | Home > Maintenance & Mods (L322) > Low boost pressure, |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 55 ![]() ![]() ![]() |
Hi, car going into limp mode If revved above 2000rpm, been told it’s low boost pressure, can anyone throw some light on this one for me please, been also advised that it could be an actuator getting stuck, problem has been intermittent up till now, thanks FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
Hi, thanks for your feedback , much appreciated FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
If it's only happening when 2nd turbo kicks in at around 2500rpm a common issue is the valve which diverts the flow gets sticky and throws a restricted performance warning. It can be seen low down on the right side by the radiator. Some 2012 cars had an updated valve which wasn't so problematic but do a search on here as there is plenty of info on this. The previous poster seems to be refering to the 3.6 engine which has different issues with it's turbo's which you don't need to worry about. 2012 TDV8 Vogue (L322) |
Hi, thanks for that, it’s restricted performance in yellow so still drives fine but if I boot it a bit it’s goes red and into limp mode, hopefully going to make it to Swanley in Kent later today for LR Technician is going to plug it in, fingers crossed FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 187 ![]() ![]() ![]() |
Apologies, I did think it was a 3.6. |
