Home > Maintenance & Mods (L322) > Components layout rear quarter 2012 Westminster
Fatfred
Hi, I have a 2012 Westminster that was taken apart in the boot rear quarter to look for possible water ingress, none was found but now I can’t remember what it looked like before, has anyone botany detailed pictures please, also throwing up turbo pressure and going into limp mode if heavy on throttle, can anyone help with this please, thanks
 FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #700566 21st Sep 2024 11:50am
Range Rover L322
Here you go, it's all on here for my 2012 AB as well as water ingress diagnosis. Change your boot seal too.
https://www.fullfatrr.com/forum/topic58516-15.html
. 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #700581 21st Sep 2024 2:33pm
JayGee
Not a westie but just a bog standard Vogue. Water ingress in mine comes from an unknown source but this lot now has a plastic sheet over it secured where the grey metal meets the parcel shelf and I've often found drips on it. The plastic bag on the left is for tehe Parking Assist Module which has been unbolted and loosley mounted upside down to prevent water running down the wires ( lost 2 this way). Mine already has the plastic sheet on the outside against the 1/4 panel. Lastly don't discount that water may not be from outside but could also be condensation. 2012 TDV8 Vogue (L322)
Post #700585 21st Sep 2024 3:29pm
Fatfred
Hi, thanks for your info lads, much appreciated FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #700587 21st Sep 2024 3:40pm
