Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322 |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
well here is my photo picture story of the fitting of the paddles to my V8 4.4 54 plate 3005 model
25th Jun 2011 1:06pm |
Well been busy this afternoon and here is the installation photo's for the receiver unit wired into the gearbox controll area and how I powered it up off an ignition feed.
25th Jun 2011 8:05pm |
Well got the air bag off once the battery had been disconnected today and got stuck in!!!!
26th Jun 2011 7:55pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
thats the easy bit if you go back to the start of the thread jonno explains where to put the wires i removed the switchs from the sender
On the back of the TX as you turn it over: left button Left solder point = common Right solder point = NC Right button Top left solder point =common Bottom right solder point = NC "RANGEISM WILL NOT BE TOLERATED" www.futuresecurityservices.co.uk Pretlove says , '' I want my car back " Last edited by pretlove on 26th Jun 2011 9:00pm. Edited 2 times in total |
26th Jun 2011 8:55pm |
whats that massive electronic box for at the bottom of your steering wheel as on mine there was nothing there and thats where i fitted the sender "RANGEISM WILL NOT BE TOLERATED"
26th Jun 2011 8:56pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
well done rob!!! its looking really good! thanks for the great write up when i was working it out on mine i completely forgot to take pics of the install!!! doh!! i was too busy concentrating it completely slipped my mine! lol
26th Jun 2011 9:39pm |
thanks matt i thought it may be that....as matt said great write up and lets not forget matt as its thanks to you and dave we have this mod at all "RANGEISM WILL NOT BE TOLERATED"
26th Jun 2011 10:30pm |
glad me and dave could be of service!!......now, whats next we all need?????? |
26th Jun 2011 10:51pm |
26th Jun 2011 11:15pm |
What would help everyone including me!, would be acouple of photo's of a wired up, swicthes removec transmitter!, any takers to supply this??? Current vehicles 4.2 SC FFRR RSE 2010- facelift Range Rover Evogue Dynamic Lux Gone Rejected RRS my14.5 nightmare Disco B4 XXV convert Freelander 06 SE 06 RFFRR 4.2 SC Vogue RSE Audi A8 4.2Tdi Quattro (hated with a vengence!!) 54 FFRR 2005 model V8 4.4 Cobra Variant 53 Mitsubishi Shogun V6 |
27th Jun 2011 7:17am |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
I'll do it later today 5.0 supercharged autobiography
27th Jun 2011 7:35am |
There's some pics in my gallery for you guys to looks at, note that only three wires are required.
27th Jun 2011 4:31pm |
jonnos photo
27th Jun 2011 4:41pm |
allisong Member Since: 28 Jun 2011 Location: UK Posts: 9 |
I have a 2007 Range Rover with heated steering wheel so do not have the additional circuits available through the "clock spring" as JLR call it, BUT studying the wiring diagrams I could see that the heated steering wheel wiring has a seperate ground and 12v supply wire (from the ignition) to the normal steering wheel switches. This is to allow it to be fused seperately I guess.
28th Jun 2011 1:17pm |
