Home > In Car Electronics (L322) > Help disconnected optical now no sound no aux |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 760 |
i had that problem, did what you have done and its been fine for several years now
19th Sep 2024 3:06am |
Lefty84 Member Since: 11 Sep 2024 Location: Essex Posts: 14 |
Is there a reset?
19th Sep 2024 7:43am |
Also, is this supposed to be connected to something? |
19th Sep 2024 8:00am |
19th Sep 2024 9:05am |
no idea what that is, is that in the rear left side RR 2005 4.4 petrol
19th Sep 2024 12:53pm |
Yes. I didn’t unplug it and I can’t see where it goes. I have a feeling it’s factory and for a piece of equipment that’s not on a 2006 vogue se. |
19th Sep 2024 2:16pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 830 |
using a factory made Car Fiber Optic Loop Connector MOST Network fits AUDI BMW MERCEDES PORSCHE would be useful, you can then test one piece of equipment at a time, could be the Bluetooth module at fault, could be something else
19th Sep 2024 2:31pm |
I picked up a bypass for the most.
20th Sep 2024 7:29pm |
I think it would be wise to test one device at a time, and see if optic light is on at every point in the chain, something in your fibre connected MOST device chain is playing up
21st Sep 2024 9:39am |
is there a plan for the fibre optic.
21st Sep 2024 9:59am |
see the graphic above, it goes in a clockwise direction - Device 1 to Device 9 ( the ampflifier) in a fully working MOST fibre ring |
21st Sep 2024 11:02am |
I GOT IT WORKING.
21st Sep 2024 7:27pm |
ok thanks
22nd Sep 2024 2:43am |
You might have a dirty fibre end connection, which is why the AHU ( Audio Head Unit) keeps resetting itself, try to clean each connection along the route with lint free wipes or some isopropyl alcohol, it must be very clean for the fiber optic light signal to operate correctly along the route. |
22nd Sep 2024 8:55am |
