Home > Technical (L322) > Whining noise
allycraven
Whining noise
My07 V8 petrol - getting an occasional random whining noise with pitch related to engine revs. No impact on engine performance or driving, just load and annoying as it drowns out the lovely V8 burble.. Happens under load and also at rest in neutral so not wheel bearing or gearbox. Sounds a bit like a high speed fan - is the main fan tied into a clutch type system? Happens more on hot day or after stop start town driving so am thinking cooling fan.
Any thoughts?
Post #70011 26th Jun 2011 12:35pm
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
i had a whining noise in mine too, it turned out to be the wife Whistle 2002 td6 vogue, 06 supercharged facelift
Post #70013 26th Jun 2011 12:41pm
darrenmax
no but seriuosly it could be a number of things, viscous fan , alternator bearings, drive belt tensioner ? 2002 td6 vogue, 06 supercharged facelift
Post #70015 26th Jun 2011 12:47pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
2 cooling fans fitted. One electric and one viscous coupling. If the noise increases with engine revs that would suggest possibly the viscous coupling could be sticking. Is the car under or over heating at all? Could be a problem with one of the thermostats. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #70016 26th Jun 2011 12:53pm
allycraven
Cheers guys, will get a better look when (if) it stops raining.....
Post #70022 26th Jun 2011 2:19pm
darrenmax
come over here, its 26°c and sunny, tomorrow its gonna be 32°c , i'm sweating already Laughing 2002 td6 vogue, 06 supercharged facelift
Post #70026 26th Jun 2011 2:30pm
scorching in swindon as well... Wink
Post #70028 26th Jun 2011 3:02pm
allycraven
Whining noise - back again....
AHHHHHHH!!! Censored Censored Censored !!!
Bloody fan issue is back again....Thought new thermostat had fixed it, but unfortunately not - turns out I just haven't had the A/C on since it was changed.... Embarassed
Done a bit of investigative work and found out that Visous fan locks on whenever A/C is switched on, regardless of internal/external/engine temperature. As soon as A/C turned off, viscous fan de-couples and all is quiet (well, as quiet as a V8 can be...).
It sounds bloomin' awful driving through town with A/C on - get all sorts of funny looks from surrounding drivers when i pull away - sounds like a turbine under the bonnet..
Anybody else have the same issue when A/C is on? Don't want to upset Dan by driving around with it off...
Post #73869 26th Jul 2011 8:58pm
HUGI
Switzerland 2006 Range Rover Vogue Supercharged Java Black
well on mine I have the fan kicking in when I drive off at home and when I'm driving slow and have the AC on. (and it is hot)
I quite like the sound: a supercharger and an intercooler together Very Happy
but I have a whining nose when I drive 60mph or more. But it is only when the engine is pulling and it is not always present. I will check if it is the fan.. you never know with this british cars Razz
Post #73872 26th Jul 2011 9:10pm
SteveMFr
Site Sponsor
Get a vacuum hose and brush and hold it out the window as you accelerate. That should get some looks. Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #73875 26th Jul 2011 9:18pm
allycraven
The first FFRR street sweeper - now there's an idea!
Post #73876 26th Jul 2011 9:21pm
allycraven
Spent a bit of time mucking about this morning, and it would appear that the noise is not coming from the viscous fan as i had assumed before.
Given it's only happening when A/C is on, I'm starting to wonder if it's actually the A/C compressor thats making the noise.
One for the dealer next week methinks. Thanks god for dealer warranties.....
Post #74154 29th Jul 2011 2:59pm
Mounty
Switzerland
Have excatly the same noise. Not bothering yet with, as the dealer just wants a lot of money per hour finding the fault. Hope your dealer finds something. Daniel
Past:FFRR 2004 Vogue 4.4l bonnatigrey/sand/ burr walnut
Modifications: SC grill (not fixed) SC MY10 sidevents (not fixed), MY10 Letters front and back, clear sidelights , MY10 rear lights (not fixed), MY09 steering wheel trims, new MY09 sterringwheel 19'' seven spoke wheel (not fixed) 19'' MTS (not fixed), 20 '' wheels, doorhandelcovers brunel (not fixed), complete doorhandels (not fixed) burr walnutdoorsouround (not fixed)
Post #74485 2nd Aug 2011 8:08am
allycraven
It's with the dealer as we speak. Will update when I get back on Thursday and give it a drive.
Post #74489 2nd Aug 2011 8:33am
allycraven
Air con compressor it was. FF is now back to singing its sweet V8 roar. Never know such a small thing could make such a racket!
Post #74941 5th Aug 2011 5:26pm
