![]() | Home > Technical (L322) > 2010 L322 with strange gearbox fault - PLEASE HELP! |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 899 ![]() ![]() ![]() |
have a look here, some useful info that could help
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 289 ![]() ![]() ![]() |
I saw a post recently with a similar fault, try switching your main lights on before starting the engine, something to do with a bad earth crimp, but if you put the lights on it provides another earth path!
gt2047 Member Since: 16 Sep 2024 Location: Somerset Posts: 5 ![]() ![]() ![]() |
Thanks for the responses guys.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
I’m assuming this is you?
Yes that’s me, thanks for watching!
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Really stupid answer coming up…….and it is, surely?……..can you try running her with the alternator disconnected or without the belt to see if something ‘that end’ is spiking the gearbox fault. Clutching at straws I know. Nice YouTube channel chap, entertaining 😁 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
As you seem to have tried everything else, could it be a faulty ignition switch? John
How would that throw a gearbox fault?
My thoughts were that there isn't an actual gearbox fault but that there is some short through the switch to the panel. Grasping at straws I know but it was just a thought.
Fair one, something is causing a “spike” in the status of the fault.
Answered my own question by watching the last couple of minutes again.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8512 ![]() ![]() ![]() |
IIRC there is a re calibration that can be done for the shift motor, I take it you have tried that..?? Pete
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
Check the part number on your old shifter and the new shifter are the same. Slight variances can cause all sorts of problems.
Hi all, thanks everyone for your suggestions. To clarify a few areas:
