Home > In Car Electronics (L322) > Sub woofer upgrade? |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
in that last pic thats where my amp is i also have those two wire/conectors you are holding its bloody confussing stuff "RANGEISM WILL NOT BE TOLERATED"
26th Jun 2011 2:17pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
OK, if you have an amp fitted in that area and those wires are still free, I guess those connectors are for sat nav or similar. Looks like I have a custom set up then, with no amp but the 9 speakers (if that would work). Yep I'm pretty confused myself now, may just give up on the idea. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
26th Jun 2011 2:29pm |
heres a pic of my amp and them two plugs you mention
The cupboard was bare lol
26th Jun 2011 3:14pm |
Not sure if the pre-facelift cars were different but, on my 2007 the sub is in that same cubby but further towards the front of the car. You have to remove the trim to get at it though.
26th Jun 2011 5:19pm |
Yeah, I know, there isn't a sub there. I was showing an empty space where the amp would be if I had one lol No longer FF owner but still interested. Present car Jaguar XE
26th Jun 2011 8:31pm |
how can you find out which of the systems you have as mine has the amp and im sure i can feel/hear a sub but i do have the standerd mid for now? "RANGEISM WILL NOT BE TOLERATED"
26th Jun 2011 9:03pm |
The sub is behind the carpeted panel just forward of the cubby hole where your amp is fitted. You should be able to see part of the black plastic enclosure peeping from behind it when you remove the access panel. According to the manual if you only have the normal amp fitted you don't have the sub as standard. Having said that according to the same manual I should have an amp to go with my 9 speakers, but I don't. Seems nothing is standard on RRs No longer FF owner but still interested. Present car Jaguar XE
26th Jun 2011 10:31pm |
thanks mike ...no sub but i got the amp at least "RANGEISM WILL NOT BE TOLERATED"
26th Jun 2011 10:33pm |
Yeah at least you have the amp, so you will be able to fit an off the peg sub by taking a feed off it. I'm stuck with what I have The Kenwood units look quite tasty. No longer FF owner but still interested. Present car Jaguar XE
26th Jun 2011 10:44pm |
i like the kenwood but the larger one only seems to be availible in america i was thinking i may go this route for now if i can run RCA's off my amp wires
26th Jun 2011 11:18pm |
