![]() | Home > General (L405) > 2019 5.0 AB - sep fob or not? |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Mines a 2018 AB and has the fuel burning heater. You don’t really need the remote though, as you can do it from the app if you pay for remote services (about £35 per year) My Previous RR's!
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 507 ![]() ![]() ![]() |
my app starts the engine (and that cant work because of the immobiliser) so would have to use a fob or the timed climate First time FFRR owner |
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 793 ![]() ![]() |
Yes, you can't operated the FBH from the app, only the remote or by setting a timer in the car. If you use the app, the engines starts, so the same as a vehicle without a FBH.
Nabbler Member Since: 11 Jul 2024 Location: South West Wales Posts: 124 ![]() ![]() |
It was quite an expensive option I believe in the petrol models. I am fortunate to have the fob and can confirm the fob will heat the car without starting the engine. The app starts the car unless you have an aftermarket immobiliser fitted. I would imagine when you do collect the car if you’ve got auxiliary heating in your home menu you just need to buy a fob ( two different types ) and program it to the car. There is a fantastic video on pairing the fob on YouTube. 2025 SV P615 2021 SVautobiography Dynamic Black ( gone ) 1997 C140 Mercedes Benz CL500 |
There you go.
smitht2 Member Since: 03 Mar 2016 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
Thanks all, and to close this thread out, when I flagged to the sales chap that the build sheet had an entry about a remote fob, he managed to find it! |
Mine has a fob, I didn’t know that remote services were different, but that’s hopefully good for me. Mines a P400e and it won’t run the petrol engine if it’s plugged in charging. It’ll warm up on electric which then defeats the object of charging it (only to use some of the range to heat it!).
DaveBL405 Member Since: 26 Sep 2024 Location: Hampshire Posts: 27 ![]() ![]() ![]() |
I have a 2021 AB - the spec sheet says 'Fuel operated heater + timer + remote' which I assume means that I should have the FBH rather than just the engine start functionality available through InControl? |
If you go into the main menu and find all the goodies the car has. If you can find “ timed climate “ then you do indeed have it. I did post in this thread what the fob looks like for a 21My and a YouTube video to pair your fob that’s is your previous owner can’t find it. 2025 SV P615
I thought I did but here you go.
Follow-up......
I’d always use the FBH. Much better than letting the engine just idle from cold, I can’t think of a scenario when starting the engine would be the better option.
