Home > Technical (L322) > Floppy wing mirror syndrome |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 572 |
Fairly easy fix. With a flat screwdriver pop the round cover under the hinged part of the arm to reveal 3 torx screws. They have most likely come loose... |
12th Sep 2024 8:40am |
Slow progress Member Since: 30 Jun 2020 Location: Derbyshire Posts: 450 |
Thankyou, will give that a go tonight 👍👍 L322 TD6 2003
12th Sep 2024 1:42pm |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 102 |
Mine does that as well, had a look at it and discovered that the play is in the gearbox on the motor.
16th Sep 2024 9:06am |
Tried the torx screws, but no improvement, mechanic thinks clutch in the gearbox had gone within the mirror mechanism, don’t believe you can buy this separately.
17th Sep 2024 11:22am |
That's a pity it didn't work. Are your mirrors folding by the button? Try holding the button pressed down for a few seconds and see if that fixes anything.
17th Sep 2024 11:25am |
