![]() | Home > Maintenance & Mods (L322) > Oil cooler coolant connecter seal ? |
PAYNTS Member Since: 23 May 2024 Location: Bedofrdshire Posts: 13 ![]() ![]() ![]() |
This is the pipe |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 325 ![]() ![]() ![]() |
A new seal doesn't help, I've changed the oil cooler unit many times, usually the diameter of the pipe leading from the cooler is 0.5mm too thin than the original LR part. I simply cut a radiator hose that was already angled and attached it with two clamps. Good luck and many greetings from Germany. L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
