![]() | Home > In Car Electronics (L322) > Sub woofer upgrade? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I have this fitted, fits nicley behind the cover on the left hand site of boot.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Been trying to find an original part, however that unit looks like a decent set-up. Will PM you for more info. Cheers No longer FF owner but still interested. Present car Jaguar XE
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 ![]() ![]() ![]() |
that does look nice "RANGEISM WILL NOT BE TOLERATED"
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Where are the rca outputs from the stereo? The only connectors I can find are related to the tv/dvd. I know where I can get the power etc but not the actual rca ouputs from the stereo for the sub? Reformed |
Tap into the cars original speaker wires that enter the stock amplifier located in the left hand side of the boot. Make sure it's the "in" side and not the output though. (You'll need wiring diagram to connect to right wires)
Sub..
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
How did you fit that in there?? In mine that section is filled with loads of control units. :shock: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Mine must be "poverty spec" |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 ![]() ![]() ![]() |
In Vogue upwards that cubby box houses the nav/tv/amp etc so there is no room for a sub in there
rich if you get the time could you show a pic of what wires you conected to as im after adding a sub to my poverty spec range as well |
Anyone know the original spec for 2003 SE? Everywhere I read about it, they say with sub. I have no sub. Is this correct or has the sub been removed at some time. If that is the case I would like to try to get an original replacement but can't find a part number or where to get one on British sites.
are they in the tailgate on ours as standerd like the later models? i know ive got one as standerd but its not up to much if im honest "RANGEISM WILL NOT BE TOLERATED"
This is a link to the us site: It looks similar to the fitment in Britain in the left rear of the car.
this is another option very much the same as rich's one but even smaller for those with little or no space
