Home > In Car Electronics (L322) > Sub woofer upgrade?
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Sub woofer upgrade?
I have a TD6 HS with single CD player and 9 speaker system. Is is possible/plausible to upgrade to a sub woofer system. The sound is pretty decent but I would like to fit a sub woofer if it didnt mean too many extra fitments or wiring etc. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #69897 25th Jun 2011 12:03am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I have this fitted, fits nicley behind the cover on the left hand site of boot.
http://www.dvbcaraudio.co.uk/kenwood-sw10-...-9328.html
Nice compact size and wires in easily as all the inputs required for sub are in the left hand side of the boot.
Post #69898 25th Jun 2011 6:42am
Mikeyjd
Been trying to find an original part, however that unit looks like a decent set-up. Will PM you for more info. Cheers No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #69910 25th Jun 2011 11:34am
pretlove
that does look nice "RANGEISM WILL NOT BE TOLERATED"
Post #69912 25th Jun 2011 11:52am
Reformed
Where are the rca outputs from the stereo? The only connectors I can find are related to the tv/dvd. I know where I can get the power etc but not the actual rca ouputs from the stereo for the sub? Reformed
Post #69913 25th Jun 2011 12:04pm
Richcl
Tap into the cars original speaker wires that enter the stock amplifier located in the left hand side of the boot. Make sure it's the "in" side and not the output though. (You'll need wiring diagram to connect to right wires)
Would take pics, but I'm at work and have no means of posting pics at the moment.
Post #69914 25th Jun 2011 12:12pm
Richcl
Sub..
Post #69959 25th Jun 2011 7:04pm
simon1233
Richcl wrote:
Sub..
How did you fit that in there?? In mine that section is filled with loads of control units. :shock:
Post #69962 25th Jun 2011 7:50pm
Richcl
Mine must be "poverty spec" Laughing
Post #69963 25th Jun 2011 7:53pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
In Vogue upwards that cubby box houses the nav/tv/amp etc so there is no room for a sub in there
I've installed a pioneer slim sub in the boot which is on show, but easily removable and very small
Wired it using a line level converter off the amp feed to the existing sub for signal, +12 comes from the 80a feed to the rear fuseboard via a 20a fuse, ground comes from the audio ground terminal block which is in the cubby box, ign switched is on the other side around the fuseboard somewhere
Excellent bass response as you'd expect (standard sub is fairly dire) and just unplugs when required to do so 2008/58 FFRR 3.6 TDV8 Vogue
Post #69978 25th Jun 2011 10:26pm
pretlove
rich if you get the time could you show a pic of what wires you conected to as im after adding a sub to my poverty spec range as well Thumbs Up "RANGEISM WILL NOT BE TOLERATED"
Post #69984 26th Jun 2011 1:31am
Mikeyjd
Anyone know the original spec for 2003 SE? Everywhere I read about it, they say with sub. I have no sub. Is this correct or has the sub been removed at some time. If that is the case I would like to try to get an original replacement but can't find a part number or where to get one on British sites.
American parts sites have the following numbers for the sub: XQA000020 or XQA50003 No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #69985 26th Jun 2011 1:33am
pretlove
are they in the tailgate on ours as standerd like the later models? i know ive got one as standerd but its not up to much if im honest "RANGEISM WILL NOT BE TOLERATED"
Post #69986 26th Jun 2011 1:42am
Mikeyjd
This is a link to the us site: It looks similar to the fitment in Britain in the left rear of the car.
http://www.roverlandparts.com/2003-2005rangeroversubwoofer.aspx No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Post #69987 26th Jun 2011 1:45am
pretlove
this is another option very much the same as rich's one but even smaller for those with little or no space
http://cgi.ebay.co.uk/KENWOOD-KSC-SW01-ACT...588bb9deb5
Post #69988 26th Jun 2011 1:47am
