Home > Technical (L405) > Rear lower tailgate will not open
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Hello everyone, I have the following problem with a customer's car: the lower electric tailgate does not open, I have already replaced the 30A fuse and the keypad switch. Is there an emergency release? The upper tailgate works 100%. I am grateful for any help, greetings from the mainland to the beautiful island! L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #699756 8th Sep 2024 10:36am
Do you have a code reader ? Are there any error codes ?
There' a full workshop manual available for download in the Wiki - link up at the top right of the page under where it says fullfatrr.com.
This is what it says -
Power tailgate does not open
Possible causes -
Low battery voltage
Mechanical obstruction
Switch failure
Power tailgate latch does not release
Soft close actuator malfunction
Power tailgate actuator(s) (upper) fail to drive
Software issue
No electrical connection / CAN bus communication
Associated actions -
Check the battery and charging system
Clear any mechanical obstruction
Check the power tailgate switch for damage/internal failure
Check power tailgate latch assembly for adjustment/damage
Using the manufacturer approved diagnostic system, check the body control module and tailgate control module for relevant DTCs and refer to the relevant DTC index
Check the condition and installation of the power tailgate
GO to Pinpoint Test B.
etc etc
Post #699761 8th Sep 2024 11:16am
Meerbusch
Hello Alistair,
first of all, thank you very much for the tip, I downloaded it and read it extensively, but unfortunately I couldn't find any instructions as to whether there is an emergency release for the lower tailgate, like on the L322. Keyboard, fuse, battery (new) checked and replaced, without result. If I press the bottom button = dead. Let's see if a reader has already had this, if I could open it then it would be easier.
Many greetings, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #699857 10th Sep 2024 7:19am
As far as I know there's not easy release option like there is on the L322.
If you really need to open it, then I guess you either have to try to get to the actuators on the side of the boot -
or to the latches on the tailgate -
This video gives a good idea of what is inside the tailgate and if you can get the back panel off, then you might be able to unbolt the latches & release that way ? 1m34s into the video shows the bolts on the latches
Clearly I have never tried this so am just guessing Smile
Post #699867 10th Sep 2024 10:24am
Meerbusch
A great thank you, I love all the videos from Raymies Garage, will try to open the lower tailgate. Car is here in Düsseldorf for three weeks for great repair, comes from Monaco, german client, and LR Nice offers him a sum more the worth of the car....... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #699904 10th Sep 2024 8:46pm
