Home > Technical (L322) > Red triangle restricted performance |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3206 |
Sounds like an intake hose has split or popped off so if nothing is obvious on the top of the engine with a visual inspection get a smoke test done ( preferably a high presssure version) to check hoses lower down. 2012 TDV8 Vogue (L322) |
9th Sep 2024 7:12am |
C11ONX Member Since: 30 Sep 2018 Location: Huddersfield Posts: 15 |
I can hear a whooshing noise, it sound to be near the fan but at the bottom. 2011 TDV8 | overfinch genuine build | mapped |
9th Sep 2024 8:47am |
Likley the hose from the main turbo or thereabouts then. I think it can be accessed from underneath if you remove the front under tray but access will be tricky from the top without removing the whole fan shroud and fan assembly. 2012 TDV8 Vogue (L322) |
9th Sep 2024 9:33am |
