Home > Maintenance & Mods (L405) > How do I adjust the ride height at one corner only?
NoHandSignals
United States 2016 Range Rover 5.0 SC V8 Aruba
Looking for tips on how to do this myself at home, or the cheapest tool that I need buy to let me do this myself at home?
I repaired (successfully I think Smile ) a leak in the rear left airbag connector, and now everything works fine, except that that corner of the car sits about 40 mm lower than the other three corners. All 4 corners go up and down fine, it’s just that whichever ride high is selected, that one corner now settles about 40mm lower than the other 3 corners settle at. No error messages.
Looks like I need to be able to adjust or calibrate a setting somewhere. Any recommendations on the most efficient, cheapest way to me to do this?
Cheers!
Post #699740 8th Sep 2024 1:37am
will308f
United Kingdom 2008 Range Rover Vogue TDV8 Orkney Grey
The gap tool would be your best choice one was for sale on here ,will save you money if you are going to do your own work 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #699743 8th Sep 2024 4:18am
NoHandSignals
Thanks, Will. Looks like that one sold and new ones are $6-700 ish. Do you know if there is anything less expensive out there that can make the necessary adjustments?
Post #699773 8th Sep 2024 1:36pm
will308f
there are other diag kits but i don't know which would be able to calibrate the height but I'm sure there is some one on here can point you in the right direction Thumbs Up 2008 3.6 tdv8 range rover Vogue Stornoway grey - Parchment Leather
Post #699774 8th Sep 2024 1:42pm
