Home > Maintenance & Mods (L405) > Fuel tank guard replacement. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
When I replaced the ARC/ACE pipes, it was pretty obvious that the original fuel tank guard made from mild steel and barely painted, was near the end of it's life. It had several holes and was rusty just about everywhere...
7th Sep 2024 2:02pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I took my rear prop off when I did the my diff pinion seal which was weeping. You need to use a 36mm spanner on the prop side. I have the JLR special tool set for the rear diff and I'd be more than happy to post the spanner to you if you would like to borrow it Pete.
7th Sep 2024 8:40pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
that fuel tank is a lovely bit of work ... - .- -.
7th Sep 2024 8:58pm |
Fisha, thanks for the info, I'll borrow Kev's spanners, that should sort it...
7th Sep 2024 9:22pm |
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 28 |
Definitely got to undo both ends of the prop, I would say. I thought one end might work at first myself when I changed my tank shield, but couldn’t figure it out. Note I did remove and replace the shield without dropping the tank though - see my earlier post on this.
8th Sep 2024 2:34am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 142 |
Psyching myself up to do this job and one of my concerns is removing the propshaft. The above info is invaluable.
8th Sep 2024 8:13am |
NHS, Thanks for the information, most helpful...
8th Sep 2024 10:40am |
Those “little ears” do look like a good idea, think I recall reading somewhere though that those “little ears” need removing for some reason on later vehicles, and that the newer version of that wrench does not have them? Easily done with a hand grinder I suppose if it proves necessary. |
8th Sep 2024 12:48pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
If you search the tool part number you can find a pdf with the technical drawing of it and it shows where the teeth need filed off. V8 or else ... |
8th Sep 2024 5:31pm |
Just to confirm, 52mm spanner fits snugly on the prop …
9th Sep 2024 11:01am |
Thanks for checking... Pete
9th Sep 2024 11:59am |
NoHandSignals.
10th Sep 2024 8:02am |
Yep, sure did. Definitely a good idea to have a fresh head for tool fitment, and they came with the locking compound already fitted.
10th Sep 2024 9:58am |
Nice, likely much better than the adjustable wrench I used, and I’m sure just as affordable! |
10th Sep 2024 10:29am |
