Home > Technical (L405) > Not starting until there is a beep
Wocko
United Kingdom 2013 Range Rover Autobiography SDV6 Carpathian Grey
so i've had a issue were i need to switch the car ignition on and off untill i hear a single beep. when i hear this and then press the ignition button again, the car will start.
it used to take a few minutes, but the process is getting longer and longer. to the tune of 15 minutes.
once driving, it can work as normal.
could this be down to a low-voltage battery?
Post #699374 3rd Sep 2024 8:47am
Checking the voltage is certainly the first thing to do, yours will probably have two batteries and if one has failed the other will do a good job of helping out until it dies...
Check the voltage on both, you can measure the main battery on the jump start posts O/S under the bonnet, to check the second battery remove the O/S rear boot side panel, this can take a lot of force, put your hand up and under the recess, there are some handy slots to get a hand in and give a good pull towards the other side of the boot, you will think it won't come but just pull harder... Check voltage on the battery posts
Both batteries want to be around 12.6 volts measured and hour or so after switch off... Thumbs Up Pete
Post #699380 3rd Sep 2024 10:20am
Wocko
The main battery ended up going dead after multiple tries.
I got a new one from Halfords and still no luck, when I put my foot on the brake it doesn't do anything.
Stop Start Battery has been dead and inactive for about 2 years and hasn't been an issue.
I still feel like i need to wait for the beep before it starts but can figure out what it indicates, might just bite the bullet and buy a StopStart battery tomorrow. reset the BMS and see where I go from there.
Post #699399 3rd Sep 2024 6:13pm
do you get this beep when using the spare key? ... - .- -.
Post #699419 3rd Sep 2024 8:18pm
Wocko
Yes
Still the same.
Going to get a Auto Electrician out today to seen if they can chase it
Post #699434 4th Sep 2024 5:59am
Wocko
i've had the car scanned and have the following faults after clearing.
Post #699539 5th Sep 2024 10:12am
Wocko
[img]https://www.fullfatrr.com/gallery/albums/userpics/27869/normal_PHOTO-2024-09-05-11-11-37.jpg[/img]
Post #699540 5th Sep 2024 10:13am
Wocko
Post #699541 5th Sep 2024 10:15am
