Home > Technical (L322) > A few battery drain questions…
Page 3 of 3 <123
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
I have an Autel AP200 on order and a volt meter. I didn’t have time yesterday but will check all the voltages when running again tonight if I get time. 2009 pre-facelift 3.6 TDV8.
Post #698994 28th Aug 2024 11:17am
JayGee
Drain the battery down and then monitor the voltages as it's charged by the car with reference to AGM charging strategies. 2012 TDV8 Vogue (L322)
Post #698995 28th Aug 2024 11:35am
KitTheRam
Steve Parker’s have now added the below page to their website. Only when they order it they use a different number as this one is obsolete despite it being what JLR’s computer kicks out. They said it’s a JLR mistake and they know the correct number but won’t tell me. All they said is it’s a flooded battery and is 90ah 950cca.
Guessing a Varta battery. He was insistent that an ‘aftermarket’ battery would cause issues. Not sure if brands make battery’s different for oems?! I thought it’s just a sticker if the brands are the same along with the ah & cca…
https://www.steveparkers.com/product/lr181...0cca-90ah/
I think I am going to swap like for like and forget about it. This is getting a bit boring! 2009 pre-facelift 3.6 TDV8.
Post #698997 28th Aug 2024 12:13pm
pjw888
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Stornoway Grey
Hi there, I would suggest it is worth a call to Tayna batteries. They may be able to advice. Service and knowledge from them is very good and at a reasonable price too. I have used them for years and never ever had any issues.
Post #698998 28th Aug 2024 12:37pm
KitTheRam
When in doubt…
Let’s hope this solves the drain issue, I can but hope. 2009 pre-facelift 3.6 TDV8.
Post #699612 6th Sep 2024 11:51am
KitTheRam
It’s been a good few weeks now and the battery seems to hold charge so my fear of a drain seems to have been put to bed (touch wood).
A question I now have - does my 07-09 L322 have a smart alternator?
I ask because when running the car with a bad AGM battery the voltage was 14.5v, after swapping the battery to a new non-AGM it reads closer to 13.5v while running. Both tested after start up when cold.
Lastly, I never did get a clear answer about the correct battery for the car from JLR. 2009 pre-facelift 3.6 TDV8.
Post #701678 6th Oct 2024 11:36pm
KitTheRam
Was looking at my build sheet today and spotted in the list:
Batteries - 110/850ah (021AT)
The Excide I recently had fitted is 100/900ah.
At least I know what the original spec was now. 2009 pre-facelift 3.6 TDV8.
Post #701875 9th Oct 2024 8:51pm
Page 3 of 3 <123
