Home > Maintenance & Mods (L322) > Raising L322 enough to lay comfortably under it
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Am going to lightly pressure wash the underside of our 2003 RR and once dry, treat it with Lanoguard or similar (open to suggestions).
Currently the raise/lower feature isn’t working (will create a separate post regarding this) so I’ll need to raise the car. I’d rather not use axle stands as the driveway is on a slight slope, what’s best to actually drive the car up onto?
Heavy duty ramps, or anything else I can use to gain another 8 to 10” clearance? What are you guys using?
Post #698911 27th Aug 2024 11:33am
PeteT80
I’ve got 4 of these. Really sturdy and good quality.
https://www.ebay.co.uk/itm/283112755483?mk...media=COPY
Post #698935 27th Aug 2024 3:17pm
DrRob
Big plastic ramps as linked above are your answer. I have them. Superb Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #698940 27th Aug 2024 4:12pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I'll 3rd that, the 4 HD ramps add about 12cm and not too expensive.
I've used on the street and the gravel drive way, very stable. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #698943 27th Aug 2024 4:42pm
Stuart-
Those ramps look quite decent. I had to use a Heath Robinson method a few days ago.
 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #698950 27th Aug 2024 5:07pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Bits of tree work for me! Razz
 The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #698953 27th Aug 2024 5:53pm
pcourtney
I have seen a few of these, seem to work well - gives max height of 47cm
Do one side at a time perhaps !
https://cjautosheywood.co.uk/product/new-mini-side-car-lift-cl22/
Post #698954 27th Aug 2024 5:58pm
thats what i call a block wood... Laughing Thumbs Up ... - .- -.
Post #698955 27th Aug 2024 5:58pm
darrenm
I bought a set of 4 ramps
Post #699024 28th Aug 2024 7:47pm
darrenm
Post #699025 28th Aug 2024 7:47pm
JayGee
Re: Raising L322 enough to lay comfortably under it
Absolutley correct - ramps are the only safe way to do it on a slope but if your air suspension is faulty and there is any danger of it suddenly dropping you would be wise to add some additional support to prevent this. 2012 TDV8 Vogue (L322)
Post #699032 29th Aug 2024 5:38am
Scouse Exile
Or you could do this Laughing
Post #699035 29th Aug 2024 7:09am
mrblonde
Thanks all
Heavy duty plastic ramps it is! Just ordered a set, hoping to get a day under her as soon as I can
Light jet wash then Lanoguard every inch of her
Post #699051 29th Aug 2024 11:29am
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I put mine into low ratio and drive it up 4 concrete builders blocks that I position in front of each wheel.. Laughing
Jim
Post #699059 29th Aug 2024 12:51pm
