Home > Maintenance & Mods (L322) > Raising L322 enough to lay comfortably under it |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 209 |
I’ve got 4 of these. Really sturdy and good quality.
27th Aug 2024 3:17pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4305 |
Big plastic ramps as linked above are your answer. I have them. Superb Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Aug 2024 4:12pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
I'll 3rd that, the 4 HD ramps add about 12cm and not too expensive.
27th Aug 2024 4:42pm |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 316 |
Those ramps look quite decent. I had to use a Heath Robinson method a few days ago.
27th Aug 2024 5:07pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Bits of tree work for me!
27th Aug 2024 5:53pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 818 |
I have seen a few of these, seem to work well - gives max height of 47cm
27th Aug 2024 5:58pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35343 |
thats what i call a block wood... ... - .- -.
darrenm Member Since: 06 Jan 2015 Location: chorley Posts: 182 |
I bought a set of 4 ramps |
28th Aug 2024 7:47pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
Absolutley correct - ramps are the only safe way to do it on a slope but if your air suspension is faulty and there is any danger of it suddenly dropping you would be wise to add some additional support to prevent this. 2012 TDV8 Vogue (L322) Last edited by JayGee on 29th Aug 2024 7:27am. Edited 1 time in total |
29th Aug 2024 5:38am |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 344 |
Or you could do this
29th Aug 2024 7:09am |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Thanks all
29th Aug 2024 11:29am |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
I put mine into low ratio and drive it up 4 concrete builders blocks that I position in front of each wheel..
29th Aug 2024 12:51pm |
