Home > Technical (L322) > A few battery drain questions… |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 420 |
That’s very kind of you, it’s a little too far for me to pop round at the moment (young child taking up all my spare time!) but if there’s an unexpected trip to my mother-in-laws very soon (Hintlesham) I will let you know.
25th Aug 2024 10:22pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
I wouldn't buy a used battery unless it's got proven history like Steveg as you will never know if the car or the battery is at fault. They are cheap enough new. 2012 TDV8 Vogue (L322) |
26th Aug 2024 8:46am |
My Ctek charger finally came today, a big improvement on my trusty old Halfords one that got me out of bother many a time.
26th Aug 2024 6:08pm |
If the car’s BMS can run an AGM battery then get an AGM battery. 2012 TDV8 Vogue (L322) |
26th Aug 2024 8:45pm |
I can only presume it can as it seems have been ok since it was fitted many years ago, I will seek clarification incase it helps anyone else. It seems that dealers were / have been fitting them to L322’s from the year 2007 and up.
26th Aug 2024 9:22pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 815 |
When you give them your VIN, also ask if the software needs upgrading so that the BMS can take advantage of an AGM battery - you may be lucky and your car is already using BMS that has the smarts to take advantage of the AGM battery ( even though we don't have Start/Stop functionality )
27th Aug 2024 9:36am |
That's one clue you may have AGM compatability as they should not be charged over 15 volts. 2012 TDV8 Vogue (L322) |
27th Aug 2024 9:47am |
Interesting chat with a nice bloke called Steve at LR Bishop Stortford.
27th Aug 2024 12:48pm |
well Steve is local to me, I used to buy from Lookers, but now I buy from Taylors in Great Dunmow, they are more switched on than Lookers
27th Aug 2024 1:18pm |
Thanks. Will have a watch.
27th Aug 2024 1:40pm |
aha, then I don't think the ECU is in the way, so no need for the TS30 torx tool
27th Aug 2024 1:45pm |
Thanks. Watched it, I guess if I replace like for like I won’t need to tell the car it’s got a new battery?!
27th Aug 2024 2:29pm |
Current state of play: everyone I speak to is confused.
28th Aug 2024 11:09am |
There must be a fairly easy test to check the cars BMS as the AGM battery has a defined battery charging sequence. 2012 TDV8 Vogue (L322) |
28th Aug 2024 11:15am |
