Home > My Range Rover > My L322 4.2 SC
Page 7 of 7 <1234567
Super Sloth
Looks a tidy example.
My 06 was a march 06 car. Just sneaked into the low tax band.
Post #674680 1st Oct 2023 5:11pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Thanks Super Sloth not quite as tidy as it looks, I need to address the rust on the offside but easiliy the best car I've owned.
Following on from my previous post the error code P0420 has returned so connected my IIDtool which promptly failed to find the engine ECU, checked with my Icarsoft reader and all is well so I updated the IIDtool and rechecked only to get this constantly rotating screen on the app. Needless to say the ignition was on.
I have now contacted Gap to see what's going on.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #676467 25th Oct 2023 11:33pm
dhallworth
Nice work on wiring up the new socket.
GAP are really excellent at support. My IID tool would read codes from the 5.0 but wouldn't display any of the live values. I pinged an email to GAP who sent me a firmware update for my tool which contained a new flash for the engine ECU. Once I'd applied it everything worked perfectly.
Hopefully they come back to you with a resolution quickly.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #676494 26th Oct 2023 1:24pm
bigbo
Been talking to Gap and need to plug it in to another RR to see if it works, if not then back to Gap but if it does work then I need to find another extension lead.
MG TF 2003
Post #683869 25th Jan 2024 2:35pm
bigbo
Further to my post on the eBay and Bargains section a nice big box arrived a few days later. Delivered to my door rather than just chucked over the fence!
Bet you cant guess what they are?
Very difficult to tell the difference between these and the originals so very pleased with them especially as they were less than £100, bargain
MG TF 2003
Post #683870 25th Jan 2024 2:41pm
DanRRL322sc
bigbo wrote:
Agree with both of you, I wonder if its because they are now new old stock and are therefore harder than when originally manufactured.
This drives me nuts!! It was one of the first purchases i made when i got my SC. But as mentioned by others previously it stayed in place about half a day. I've refitted it 4 times now and finally gave up and left it off, but every time i open the upper tailgate the naked button bothers me Confused 1988 Classic 3.5 EFI in Green - GONE.
1993 Classic 3.9 Vogue SE in Green - GONE.
1997 P38 4.6 HSE in Blue - GONE.
2002 P38 4.6 Vogue in Black - GONE.
2007 L322 4.2 SC in Java Black.
2007 Audi TT 3.2 V6.
1988 Porsche 930 turbo.
Post #685154 9th Feb 2024 7:44am
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi Bigbo, can you post some images when the steps are fitted. It will be great to see what they look like fitted. Thumbs Up 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #685387 11th Feb 2024 8:24pm
bigbo
Yes I will put pictures up, but don't hold your breath it will be a while before I get around to that.
MG TF 2003
Post #685490 12th Feb 2024 10:36pm
bigbo
Finally got around to updating my post.
Early on this summer I decided that I really wanted my A/C working so purchased a diy kit from ebay consisting of hose and pressure gauge, 2 cans of gas and a can of sealer for less than £80. A straightforward job to do and I have a spare cylinder should it leak in the future.
The next task was drilling out the 3 snapped 6mm screws from when I removed the side steps. There is little room to get a drill and bit in place, so I used an air 90o drill and managed to drill out to 4.5mm in steps from 2mm trying to remove the screws using stud extractors but unfortunately they failed to move.
I should add that I had to buy an expensive set of cobalt drill bits as nothing I had would touch the broken screws.
Couldn’t get a 5mm drill in the gap so I cut 20mm from the shank to shorten it. If you try to do this when you tighten the chuck make sure it grips the shank and not the fluted section. I’ll let you guess how I know!
1 captive nut fell off inside the cill so out with the clinch nut kit. I needed to drill a 9mm hole for the clinch nut so I had to buy a step drill as none of mine had a 9mm option.
So, the easy bit hanging the steps, you would think, maybe because I was doing this by myself it was very tricky, especially as I assumed that the slotted screw holes in the vertical hangers of the steps would allow me to fit all 4 screws and then to slide the steps on before tightening. I couldn’t find the movement to make this happen, so I propped the step on my chest added 1 screw and then lifted the steps to add a screw to the other end. I added enough Loctite to ensure the threads were completely covered to help against future rusting.
I need to fit the front mud flap but test fitting shows that a soak in hot water will help to position it correctly. I will then post some pictures.
Next task is to replace the coolant tank as I have had enough of the warning message.
When buying the tank I added the two camshaft position sensors to the list without first checking how easy replacement is. I now know that I have to remove the throttle body to get at them. Unless anyone knows better?
Whilst under the car I noticed that the offside step needs replacing so out with the plus gas as often as I can before starting the job.
MG TF 2003
Post #698396 19th Aug 2024 2:23pm
bigbo
Another item I had to replace was one of the reg plate lamps, found during the MOT apparently not a failure because there are two of them, Fist time I have had a "Pass with Defects"
I know these are on the check sequence of the LCM so didn't know that a lamp was out.
On checking I found that the LED lamp had failed but in such a way that the LCM had not noticed. So just because you have no message it doesn't mean your lamp is working.
So back to manual checking for those.
MG TF 2003
Post #698403 19th Aug 2024 2:53pm
bigbo
Picture of fitted step as requested
Yep car needs a clean, I'll get round to that soon.
Next job the expansion tank. Tomorrow I hope.
Also I have decided that I will replace the step mounting screws with stainless so they are on order.
MG TF 2003
Post #698657 23rd Aug 2024 12:16am
bigbo
Fitted the expansion tank, a surprisingly easy job.
Clamped top and bottom hoses
undid the two screws holding the tank in position, but as usual the screws were badly rusted and took 1/2 hour to remove, I really did not want them to snap.
I applied Vaseline to the mounting spigot and the u shaped bracket as well as the hose inlet and outlet.
The new tank was easily slid into place and secured with stainless screws.
A job made easy by using some new tools purchased for this job.
I especially liked the hose clip pliers, I have got away for years using standard pliers which often slip off at the wrong moment, but these work really well.
MG TF 2003
Post #698797 25th Aug 2024 12:41am
th3chainrule
United States
bigbo wrote:
I managed to do the Supercharger oil change that I promised the car since I bought it.
I know a few people on here have mentioned that the photos are missing from the post in the wiki, I hope these help....
First an under bonnet shot, all SC owners will recognise this and yes the engine cover is missing.
Here is a shot to show the difference between old and new. The only worrying thing is that this is after only 15k miles so I intend to do this again at the next engine oil service in about 5k miles.
Getting the plug back into place was very difficult, I asked my wife to give it a go as she has small hands, but that didn't work and as my hands were too big to get access, I removed the bolt holding the front of the Throttle Body Intake down and as it has a rubber collar at the Throttle body end I was able to lift it enough to get my hand in to insert the plug. Otherwise I would have removed the Throttle Body Intake, an easy job but you need to remove the Plenum Chamber to do so.
So an easy job made difficult by access issues Personally I would change every 20k not 50k as others including the oil suppliers recommendation of 50k, the cost compared to a rebuild/replacement of the supercharger makes it a no brainer!
David
Do you know if this is identical for the 5.0SC oil change?
Post #698828 25th Aug 2024 5:22pm
dingg1
I'd guess so, but changed my oil on the sc and wish I'd never bothered tbh 130000m clean as a whistle and a pain in the arse to change, you must take off the throttle body intake to make it easier....
Ime the oil will last until the car dies unless something else is going on....
Post #698841 25th Aug 2024 9:51pm
bigbo
I cant answer regarding the 5.0, Dhalworth would be able to help as he has owned both.
I still think that it pays to change the oil regularly my next service is about due and the sc oil is definitely on the to do list, its cheap to do and now that I know how to get the plug back in without dismantling everything its a straight forward job to add to a normal service.
MG TF 2003
Post #698843 25th Aug 2024 11:11pm
