Home > In Car Electronics (L405) > Map Updates not Updating
Page 3 of 3 <123
Gremlin500
Hi Arch, this thread may help:
https://www.fullfatrr.com/forum/topic63745.html
(I hope the above appears as a link, HTML seems to be broken for me on here? Stan?) “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #698767 24th Aug 2024 12:06pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Cheers gremlin, looks like my original stick was a USB2, so just bought a 64GB USB3 to see if that makes a difference. It started to download without having to be reformatted and it appears to be downloading from HERE a little quicker so fingers crossed.
ETA - download onto the new stick took less than an hour, will try it in the car after the footy First time FFRR owner
Post #698773 24th Aug 2024 12:33pm
Gremlin500
Arch, did you check your system voltage?
It needs to be around 12.5V or better in my experience. All my early woes were down to a weak battery.
Turn off all unnecessary electrical equipment, and maybe put a charger on if needs be.
Having said that, my car has done the updates like clockwork now for over a year, but I had one fail recently or rather fail to start, and ended up with no maps installed whatsoever! -I re-downloaded the file and tried again and it worked, so I think you’re right in that files can get damaged and fail the checksum due to the huge download size and time taken.
I have two super-duper Sandisk Ultra Flair 64Gb sticks which I alternate for maps anyway, so I can revert to an older, working map if needs be, I think this is a good/prudent idea.
Good luck! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #698781 24th Aug 2024 4:43pm
Arch Stanton
All sorted now thanks Gremlin, I bought a new Samsung USB3 64GB stick downloaded the maps in less than an hour and it uploaded to the car straight away and finished in 20mins. Smile First time FFRR owner
Post #698787 24th Aug 2024 7:06pm
Gremlin500
Result! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #698788 24th Aug 2024 7:15pm
Page 3 of 3 <123
