![]() | Home > General (L405) > About to upgrade - a couple of questions |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35546 ![]() ![]() |
it would be great if the built in cameras could be used but unfortunetly they cant.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 754 ![]() ![]() |
If you're buying yours as an approved used LR vehicle then there might be a way to get an extended warranty.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 919 ![]() ![]() |
The generic LR front and rear dashcam is very good. Thankfully I have not needed to use it as evidence in any sort of situation, but they work well with the app and it's easy to use. All LR cars from 1984
smitht2 Member Since: 03 Mar 2016 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
I like this idea!! Can I ask - is this the "Full" LR extended warranty, not the lower version with a lower limit on claims? If it is the full one, then I'm tempted to do the same, and get Finance to get the 2nd year warranty and then pay it off. |
Yes it is the unlimited version, |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 507 ![]() ![]() ![]() |
Re the LR extended warranty, I am coming towards the end of my 2 year deal and would rather like to extend it further, is that possible do we know?
if its under 10 years old and under 100k miles then you should automatically get a 'welcome' pack through the post.. |
lovely cheers Stan, First time FFRR owner |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1481 ![]() ![]() |
Quite straightforward to fit dash cameras. The front one you can either buy a piggyback loom that plugs the camera into the power supply to the interior lights in the overhead console, or you can send the wire down the A pillar into the fuse box and run it from the heated steering wheel fuse (if you want it ignition controlled).
Eddthedoc Member Since: 07 Jan 2024 Location: Norfolk Posts: 8 ![]() ![]() ![]() |
Thanks so much everyone. Really helpful replies.
