Home > In Car Electronics (L322) > DIY 3 button key transponder programming & sync-BMW era
Khalid
Qatar 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Thank you for your advice.
I will await the reply of Duckworth then and hope they can make the full key (Plan A).
Kind regards,
Khalid
Post #697835 11th Aug 2024 1:09pm
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
What would be the difference for 2005 RR HSE US version?
Ideally without any need to remove console or parts. I am planning to get GAP IID tool, will it help?
Post #698338 18th Aug 2024 7:21pm
pcourtney
Well first you have to establish if your car uses EWS3 or EWS4, being a 2005 vehicle it could be either, and what exact engine do you have in your car ?
What transmission do you have ? this is the easiest way to tell - from 2005 until 2009 a 4.4-litre Jaguar-derived engine or a 4.2-litre supercharged variant of the Jaguar engine partnered with the ZF 6HP-26 transmission
and no the GAP IID will be of no use to you if it's earlier Petrol BMW M62 V8 engine !
Post #698399 19th Aug 2024 2:38pm
invisible999
Well, it is BMW M62 engine with ZF5 transmission.
Post #698401 19th Aug 2024 2:52pm
pcourtney
same as mine Smile
sadly you do have to access the EWS3 box in the centre console, your best bet is to find a small BMW shop in your town, as they know best how to code these EWS3 boxes , same thing in BMW X5's and E39 models, so very common problem for most good mechanics
Post #698407 19th Aug 2024 3:22pm
