![]() | Home > Maintenance & Mods (L322) > Cleaning injectors via ultrasonic? |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3142 ![]() ![]() ![]() |
When the injectors were removed from my 4.2SC I sent them to MrInjector who spray tested them all for me. A couple weren't quite up to spec so they were all cleaned and rebuilt and sent back to me with a before and after report.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
Send them to a specialist if you take them out, they will have all the specialist tools / test rigs to overhaul and test the injectors. the tools / gear used are definitely not tools people have in their garage at home !! |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 835 ![]() ![]() ![]() |
my advice is the same, if you are in London next time, take them to CFI, they are the best |
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 ![]() ![]() ![]() |
Thanks everybody.
@Dhallworth question for you.
Addam Mannion Member Since: 09 Sep 2024 Location: Manchester Posts: 1 ![]() ![]() ![]() |
Ultrasonic cleaning is a highly effective method for cleaning fuel injectors. It uses high-frequency sound waves to create microscopic bubbles that can penetrate small passages in the injectors, removing carbon buildup, dirt, and other contaminants that can impede fuel flow. This method restores injectors to optimal performance without the need for harsh chemicals.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 ![]() ![]() |
First post spamming your own business, well done 👍 |
Sorry Conor, I didn't see your question.
