Home > Technical (L322) > Update to air suspension problem |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Hi, as previously posted having an issue with the car dropping at the front when parked up.
18th Aug 2024 12:52pm |
Thanks for the reply, I just checked with soapy water and its coming out at the bottom of the airbag just under the folded part. |
18th Aug 2024 4:34pm |
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 |
That's always the first thing to check - its the most common failure. |
18th Aug 2024 5:09pm |
Looking at the difference between swapping the air bag compared to the whole strut I’m thinking of just changing the whole strut as it’s not a massive job. I have the Gap to calibrate the suspension and don’t see any big issues changing it myself and saving on garage labour costs. |
18th Aug 2024 5:52pm |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 753 |
Save yourself from future grief and do both fronts at the same time. The older I get, the more I realise that people confuse wrinkles for wisdom |
18th Aug 2024 9:27pm |
