Home > Wheels & Tyres > L663 Defender alloys on the L405
Page 3 of 3 <123
Nonterraquous
Scotland 2015 Range Rover Vogue TDV6 Causeway Grey
Buz1500 wrote:
I’d be interested to know if anyone has fitted the Defender style 5098 in dark satin to their L405.
These ones?
Post #692452 12th May 2024 2:00pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Perfect... thank you. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #692506 13th May 2024 8:20am
pasha0305
United Kingdom 2016 Range Rover Vogue SE TDV6 Santorini Black
Just to throw my hat in the ring regarding Defender wheels on an L405. I had 22” turbines at when I purchased the car and now I have the “magic carpet” ride! Finally!
Would highly recommend!
Post #698260 17th Aug 2024 6:15pm
pasha0305
Here is a pic
Post #698262 17th Aug 2024 6:16pm
__CA__
United Kingdom 2014 Range Rover Vogue TDV6 Luxor
Good info in this thread, thanks for sharing. I am in week two of FFRR ownership and have a question for those running the Defender tyre size (810mm or 31.9 inches diameter) - have any of you experienced air suspension failure, will the tyres rub / can the car still move when it's sunk to the bottom of its travel?
I am buying 19" Defender wheels (style 6010) because I have an off-road adventure coming up in Morocco and want as much sidewall as possible. I have a TDV6 with small brakes so 19s will fit. Small Defender wheels are remarkably cheap, I have won a brand new set of take-offs with new Continentals for £325 but don't physically have them yet.
Ideally I would like to use the Defender size 255/65 which gives me 165mm sidewall, or I could play it safe with 255/60 which is 153mm sidewall and matches the L405 normal diameter. Knobbly all terrains with deep tread will add a bit vs a normal road tyre. I don't plan on using the Continentals in Morocco as I want as much puncture resistance as possible.
Thanks, and I will post photos once fitted.
Post #714350 18th Mar 2025 3:40pm
Page 3 of 3 <123
