Home > Maintenance & Mods (L405) > Side step collapse!
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Side step collapse!
So my near side side step (which I think is original LR) has given out whilst on holiday in Cornwall. A combination of rust, repeated roof box access and an Xxl owner have caused it to give (with an awful, rusty crunching sound!).
I couldn’t see any single used ones on eBay, so started looking at new ‘aftermarket’. There were some threads from a few years ago but looking for any recent recommends for good value steps that will take the weight of a real man Rolling with laughter
Do aftermarket steps fit onto the LR brackets (which I hope are still good) or is it a full replacement?
Does anyone have a left side step? My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #698114 15th Aug 2024 10:05am
kevin-t
I had some fitted approx two years ago From a company called:
www.sidesteps.co.uk
They are on my sport L494. Was recommended by a fellow member on that site (Tyrefitter) Andy.
Went to their place in Northampton. steady drive down and back, all fitted in less than one hour.
Look as good today as when fitted, super strong, By far superior quality to those I had on my Disco 3.
Me approx 6' 18 + stone No problems whatsoever Thumbs Up Thumbs Up Thumbs Up
Not the cheapest, however Look great and You can see the quality.
Cost me around £400 fitted. very happy Thumbs Up
Post #698116 15th Aug 2024 10:34am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Re: Side step collapse!
Unnecessary quote removed
easy tiger, mine did this. If yours had the same failure as mine, what happened is the rivets securing the silver metal trim had corroded then broken when flexed when my lump of a carcass stepped on. I drilled the remaining rivets off and drilled pilot holes a bit bigger and self tapping screws to put the trim back on. The step was fine. Both sides eventually did it but it's a quick and easy fix. Have a look underneath and see what's going on First time FFRR owner
Post #698117 15th Aug 2024 10:55am
Arch Stanton
beautiful car btw First time FFRR owner
Post #698118 15th Aug 2024 11:01am
hoppy_70
Cheers Arch, I’ve paused on the eBay purchase for now then, I love a money saving repair! My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #698153 15th Aug 2024 4:58pm
Arch Stanton
hopefully it is the same problem, the design looks exactly the same as mine. the first time if happened I thought the same as you, a horrid crunching noise but as more rivets came off it became more obvious. Mine have been great since the repair and I love having the steps, I know to everyone does. First time FFRR owner
Post #698155 15th Aug 2024 5:23pm
hoppy_70
Did you take them off to fix them, or do it in situ? My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #698169 15th Aug 2024 10:19pm
Arch Stanton
put it in off road height and drilled off the remaining rivets, releasing the trim, then drilled the pilot holes then put in the self tappers. there may be easier methods though First time FFRR owner
Post #698170 16th Aug 2024 1:08am
Arch Stanton
eta, the steps stayed in situ, I just removed the trim from underneath First time FFRR owner
Post #698171 16th Aug 2024 1:09am
hoppy_70
Ace, thanks Thumbs Up My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #698174 16th Aug 2024 7:47am
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
I have a reasonable pair of used steps (fixed type) if anyone needs them….
Post #698201 16th Aug 2024 4:12pm
hoppy_70
Hold that thought Richie, I’ll have a look at it when home on Sunday and see if it’ll fix first Thumbs Up My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #698215 16th Aug 2024 7:24pm
I have a few sets of used Gen JLR steps removed from customer cars... If anyone wants some? Send me a PM Thumbs Up
Post #698316 18th Aug 2024 5:12pm
