Home > Maintenance & Mods (L405) > Serpentine Belt Keeps falling off.
p38paul66
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
So A bit of a long shot. I have 2013 sdv8 4.4. Which for the past 6months or more keeps throwing the aux belt. This all started 9months after replacing the alternator. Things that have been tried so far are:
Second alternator.
Water Pump.
Tensioner x 2
Idlers X 2
So far no change what so ever.
Symptoms: Start the car and you can hear a clicking noise. On every click the belt moves 1 - 1.5 cm on the bottom idle pulley. If I leave the car the click goes and I have no further issues with belt movement. If I have not waited for the clicks to finish then the belt may or may not fall off.
There are no issue with starting and as I said once running it will do so for the rest of the day. Only when left for 7-8 hrs does the problem reoccur.
Post #697894 12th Aug 2024 2:05pm
Weegie
Don’t know about the L405 but when getting a new belt for my L322 I found that there were two different possibilities. The difference was that one belt had fewer grooves. Wonder if that could be a possibility? John
GAP iiD BT
Post #697901 12th Aug 2024 3:52pm
p38paul66
Hi thanks for the reply. But as far as I know this is only a 6toothed belt pk6 . The total length can be +- 5mm . It started with a gates belt which was 2498mm and currently I have an INA belt which is 2500mm. This one has yet to fall off. But mainly as I am waiting longer before I set off. The car is booked in to an indi but earliest appointment is 5th September.
Post #697915 12th Aug 2024 6:37pm
knwatkins
It sounds like something wasn't properly aligned when the alternator was fitted. The Gates 6PK2500 is a good belt. I have the same one on mine. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #697917 12th Aug 2024 6:47pm
p38paul66
From what I have read, that would be my conclusion. However the alternator has been replaced since then and also it ran for 9 months before it started falling off. After a minute or so the belt runs true. It only jumps on the clicking sound.
Post #697919 12th Aug 2024 6:58pm
GraemeS
Genuine or after market tensioner? Some after market ones have been reported to be sloppy from new.
Post #697930 12th Aug 2024 9:38pm
p38paul66
I have tried both oe and aftermarket.
The results were the same.
Post #697936 12th Aug 2024 10:52pm
kevinp
I'd take the belt off and get a straight edge to make sure all the pulley faces align.
Check the water pump has no play. Could the water pump be the source of the clicking? After 5 minutes of running it might have expanded enough with the heat of the water to get a clearance gap again.
Post #697958 13th Aug 2024 9:09am
p38paul66
Hi Thanks for the reply.
I have changed the water pump. the clicking was therebefore and no change after. The time it takes for the clicking to disappear is less than a minute. So would have no chance to warm up enough to affect anything there. This is why this is so confusing and difficult to find. I also tried the straight edge, but again nothing seems out of alignment. Also if it was why, would it after the minute all re-align. My own thoughts at the moment are the aircon compressor. But if this is off with the climate control why would be trying to engage at startup and then why would it not continue when compressor goes on and off. I think the gas levels are low at the minute 925Kpa. but would this affect the system and possibly cause it to switch (Click) ?
Post #697964 13th Aug 2024 9:48am
GraemeS
I consider that mine's clicking it due to the join in the belt. As soon as the belt softens it becomes more flexible so doesn't cause the tensioner to jump.
Have you watched how close the belt runs to the front of the tensioner pulley when cold and if it moves back once warm?
Post #697968 13th Aug 2024 10:01am
p38paul66
Hi. These modern belts are fairly seamless and I have had to change 2 or 3 now. Again, no difference even when the belts are different lengths or manufacture. Also only used Gates and INA. As for the movement of the belt , this is as mentioned in my first post.
Start the car and you can hear a clicking noise. On every click the belt moves 1 - 1.5 cm (in and out) on the bottom idle pulley.
This is the pulley by the alternator and straight after the tensioner. There is very little movement of the belt, on the tensioner pulley.
Post #697972 13th Aug 2024 10:24am
Gremlin500
No offence intended, just it’s best to start with the basics, are you 100% sure the belt is routed correctly? Then check alignment, check faces of pulleys are all parallel, then check belt tension.
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/normal_IMG_0850.jpeg[/img]
A short video might help us.
Post #697976 13th Aug 2024 11:08am
p38paul66
haha no offence taken.
Any help on this would be great.
Here are 2 videos from startup. Not a great, but you can see the belt jump on the click.
https://youtu.be/toMix3Jzgd0
this second video was from a few months back.
https://youtu.be/RvYQf-N_bjE
Post #697985 13th Aug 2024 2:20pm
kevinp
Sounds like you have a squeeky pulley bearing somewhere. Have you changed ALL the pulleys?
Post #697986 13th Aug 2024 2:29pm
p38paul66
I have had all idle pulleys and the tensioner replaced. The squealing is actually a new noise within the last week or 2. I have not changed the Active cornering pump or the compressor. My feelings were these are too far away from where the problem is occurring. But more than happy to be proved wrong.
Post #697988 13th Aug 2024 2:36pm
