![]() | Home > Maintenance & Mods (L405) > Serpentine Belt Keeps falling off. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3247 ![]() ![]() ![]() |
Don’t know about the L405 but when getting a new belt for my L322 I found that there were two different possibilities. The difference was that one belt had fewer grooves. Wonder if that could be a possibility? John
p38paul66 Member Since: 11 Jul 2023 Location: lydbrook Posts: 20 ![]() ![]() ![]() |
Hi thanks for the reply. But as far as I know this is only a 6toothed belt pk6 . The total length can be +- 5mm . It started with a gates belt which was 2498mm and currently I have an INA belt which is 2500mm. This one has yet to fall off. But mainly as I am waiting longer before I set off. The car is booked in to an indi but earliest appointment is 5th September. |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 771 ![]() ![]() ![]() |
It sounds like something wasn't properly aligned when the alternator was fitted. The Gates 6PK2500 is a good belt. I have the same one on mine. Kev
From what I have read, that would be my conclusion. However the alternator has been replaced since then and also it ran for 9 months before it started falling off. After a minute or so the belt runs true. It only jumps on the clicking sound. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2575 ![]() ![]() ![]() |
Genuine or after market tensioner? Some after market ones have been reported to be sloppy from new. |
I have tried both oe and aftermarket.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1281 ![]() ![]() ![]() |
I'd take the belt off and get a straight edge to make sure all the pulley faces align.
Hi Thanks for the reply.
I consider that mine's clicking it due to the join in the belt. As soon as the belt softens it becomes more flexible so doesn't cause the tensioner to jump.
Hi. These modern belts are fairly seamless and I have had to change 2 or 3 now. Again, no difference even when the belts are different lengths or manufacture. Also only used Gates and INA. As for the movement of the belt , this is as mentioned in my first post.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1607 ![]() ![]() ![]() |
No offence intended, just it’s best to start with the basics, are you 100% sure the belt is routed correctly? Then check alignment, check faces of pulleys are all parallel, then check belt tension.
haha no offence taken.
Sounds like you have a squeeky pulley bearing somewhere. Have you changed ALL the pulleys? |
I have had all idle pulleys and the tensioner replaced. The squealing is actually a new noise within the last week or 2. I have not changed the Active cornering pump or the compressor. My feelings were these are too far away from where the problem is occurring. But more than happy to be proved wrong. |
