Home > Maintenance & Mods (L322) > What’s the book time to replace LR019598 a/c hose?
WeiB.beer
United Kingdom 2012 Range Rover Westminster TDV8 Fuji White
My a/c hose has been diagnosed with a leak from part no. LR019598
Can anyone tell me the book time to replace this, and do you have any hints/tips to get the job done?
Post #695424 2nd Jul 2024 5:42pm
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
I have done the equivalent pipe on a 3.8 V8 (twice) They can be a real PIA. The first time was easier than the second for some reason. The only extra thing I had to remove was the header tank and the heater intake box (2 bolts) I would allow at 2 hrs plus the regas 2010 3.6 TDV8
Post #696056 12th Jul 2024 10:16am
WeiB.beer
Oh that’s great news! It’s off to a LR/RR specialist to have this done so my expectations of the invoice have improved Bow down
Post #696062 12th Jul 2024 10:47am
RRYorks
They may be some difference between the 4.4 and 3.6 so bear that in mind, and always get an estimate upfront! 2010 3.6 TDV8
Post #696066 12th Jul 2024 11:36am
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Did you get this done in the end?
Having had a mobile guy out to check and regas mine this morning as it wasn't blowing cold, exactly the same pipe seems to have rubbed itself through, so I'm going to have to replace!
Post #697857 11th Aug 2024 8:23pm
WeiB.beer
Hi, yes I did get this done, just in time for a 2 week road trip, UK>France>Spain>Monaco>France>UK. The AC blew perfectly cold for the entire journey, where it was up to 40c outside.
Cam-Tech Craig did the ac work for me, as well as replacing the vacuum pump, crank seal and the aux belt.
I couldn’t recommend Cam-Tech highly enough! (But it may not suit your location).
Post #697859 11th Aug 2024 8:41pm
paulbrown22
Super, thanks - I'll order up the parts and see what I can do then!
If I lived the other side of London I'd very happily use Craig given his reputation on here, but from the east side I've been using Steve at Brownchurch for nearly 20 years to look after all my Land Rovers who I'm also super happy with.
I'll hopefully do the work myself if time between work and two small children allow, but if not will get it to Steve....
Post #697860 11th Aug 2024 9:00pm
