Home > Off Topic > New driveway solutions?
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Morning all,
I'm going to have the drive surface relaid and would like views on what solutions to avoid, with our motors being the best part of 3t and I can park the car within an inch or two of being in the exact same spot each time, I want to avoid 'tram lines' and depressions where the wheels will be constantly sitting.
I'd avoid a gravel as they get messy but the porous composite materials look good or should I still with old fashioned asphalt?
Does anyone have any experience of these (good or bad) or any other solutions?
Thanks
Arch First time FFRR owner
Post #697811 11th Aug 2024 8:02am
theres a couple around the corner from me that had coloured tarmac laid for a cost of £7k....unfortunately trams lines appeared shortly after because as in your case they parked in the same place ..
sorry that this is no help to you but it might help you to make a decision.. ... - .- -.
Post #697814 11th Aug 2024 8:29am
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
I had my worn out tarmac replaced with Cotswold stone (20mm chipping) and it is proving to be a good choice after 2 years. It looks beautiful, porous for rain discharge, doesn’t spread like gravel as it is angular and ‘locks in’. Really pleased with it.
However, I would not have used that if I did not have my garage where I can jack etc on a solid concrete floor as would want to be jacking on the Cotswold chippings.
Price wise it is just over £100 per tonne. You will need a tonne per 4SqM at 150mm depth.
Porous composites are good but don’t go cheap on this or you will regret it. Some firms offering a cheaper option and they save costs by not doing the prep work to the correct standard on the substrate and a cheaper grade material for the resin. You really want commercial grade if you want it to last, as you say we are not parking a cinquecento on there!
Post #697815 11th Aug 2024 8:30am
Arch Stanton
that is great info thanks Stan, is this the composite stuff? First time FFRR owner
Post #697816 11th Aug 2024 8:38am
Arch Stanton
thanks Alex, is yours a resin bonded stone? that sounds very interesting, dont suppose you have a picture you can post? First time FFRR owner
Post #697818 11th Aug 2024 8:40am
i dont know the type of stuff they put down but it did look very nice when new and not like regular tarmac. ... - .- -.
Post #697819 11th Aug 2024 9:00am
I wouldn’t touch any form of tarmac. Unless it’s machine laid it’s never truly even so that every time it rains you get puddles. I have shingle which always looks the same whatever you do to it. I do however miss an area of hard standing for car maintenance etc. Thumbs Up
Post #697820 11th Aug 2024 9:01am
maybe a slab of coloured concrete [if thats a thing] ... - .- -.
Post #697821 11th Aug 2024 9:18am
Merchy
My brother had a 'red tarmac' laid on his driveway a few years back and it still looks good with no tramlines.
For a living he inspects every stage of building / construction, from high rise buildings to extending runways for aircraft and he was very particular with his specifications for construction, the sub-base he had laid down was quite deep and very well compacted, which helped stop the tramlines.
it appears that you could park a tank, let alone a RR on it without damage Rolling with laughter as for cost, it was not cheap Big Cry
Post #697822 11th Aug 2024 9:19am
rjff
If you are looking at resin bound you may want to consider Addagrip.
They have approved contractors and have warranties to 10-15 years. However it is expensive, currently the ball park is £40-70 for drives. It does meet SuDS (drainage) requirement for planning.
The substrate you have may need upgrading to suit.
It is availbe for footways, drives and commercial car park surfacing and I have used it for a large area in front of a building but that was very much foot traffic. Did use a 95GVW crane on it for a few days albeit with boarding without damage. Cheers
Richard
Gap IIDBT
Post #697823 11th Aug 2024 9:21am
Yep - it's all about the preparation & base layers, not what's on top.....
Post #697824 11th Aug 2024 9:23am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I have small pebbles / gravel, it's the cheapest option but it does tramline so I rake it regularly, takes about 5 mins and it's good as new. Anything else will sag and crack over time, it's inevitable, however, some can easily be relevelled and drain naturally, asphalt & concrete cannot be invisibly repaired and do not drain well.
Downside,you do get crap in the carpets if you're in and out on a rainy day and it's a pain for my HD trolley jack to move round on being as it's so heavy so as a jack base I have 2 x 6 ft scafolding boards for the base and I move the trolley jack on a roller board. The good news is if you spill oil or have a leak you just need to rake it over and it's all gone.
Whatever surface, it's all about the foundation, you'll need at least 1 foot deep compacted 3" aggregate and another 4 to 6 inches compacted 1" aggregate on top of that, then your finishing surface needs to be no less than 2".
Even then it will sag eventually. Concrete will sag or tilt under it's own weight, eventually cracking at the edges, so will asphalt and any repairs will stand out like a dogs boll***s at a wedding. With resin, choose a light mixed colour, you'll notice any sag less. My last house was block paving, about 6" light grey cubes, that sagged after a year or so, but you can lift it, sprinkle a little sand and re lay it again very easily, 2nd year a little sag, 3rd year no sag.
I'd go for big block paving over a good agregate base of at least a foot. It will last the longest and still look good plus it's easy to re level and after a couple of years of natural settlement should stay pretty level and drain well.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #699273 1st Sep 2024 8:01pm
We have a significant area of 20mm Basalt chippings which I've put in the plastic honeycombe structure you may have come across. They hold the gravel in place (despite slopes) and it doesn't tram line as long a you only go a few mm deep on top of the plastic grid. Only maint I've needed to do in a couple of years or so is add a little more gravel where it had settled and you could start to see the grid edges - looks better when they're properly buried, but go too deep and you get tram lines.
But of course we all need a hard standing to operate a machine wash bay - doesn't every house have one??? Rolling Eyes
 Mike - MPx
Post #699285 1st Sep 2024 10:03pm
AndyRoo
Is that a cheaky M100 poking it's bum out there ? Very nice toy.
Post #699286 1st Sep 2024 10:08pm
Oh yes! Been a Lotus fan boy for more years than I care to remember. Doesn't usually live there - normally tucked up in the barn...
Apols for going so far off topic Embarassed Mike - MPx
Post #699287 1st Sep 2024 10:18pm
