Home > Technical (L322) > Brake pedal sinks to floor |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3249 |
The front calipers are aluminium alloy so the issue is galvanic corrosion. 2012 TDV8 Vogue (L322) |
9th Aug 2024 2:24pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 400 |
anythin can be done to prevent? Its actually a sport
9th Aug 2024 2:27pm |
ah okays, i did that so hopefully they dont snap.
9th Aug 2024 3:51pm |
You can also buy alloy 'racing' bleed nipples which would avoid the galvanic corrosion. 2012 TDV8 Vogue (L322) |
9th Aug 2024 6:25pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Can you clarify when you get your sinking pedal ?
9th Aug 2024 6:32pm |
Ian_D Member Since: 07 Aug 2024 Location: Barnsley Posts: 8 |
Pawl, for me its every time when the engine is running.
9th Aug 2024 9:59pm |
Based on when it happens, I agree with you, it's very likely to be the mastercylinder.
9th Aug 2024 10:25pm |
Tested mine today and can get the pedal to slowly sink to the floor with the engine running if I press hard enough.- way harder than I would press it even in an emergency. 2012 TDV8 Vogue (L322) |
11th Aug 2024 4:58pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 347 |
[quote="Pawl”] If you're holding the pedal down while the engine is starting or immediately after starting, you may not have a "real" problem - as when the engine starts the vacuum pump immediately starts building / restoring vacuum in the brake booster - adding assistance to the effort from your foot and causing the pedal to go down further. Once the vacuum is stable, there won't be further assistance so the pedal won't sink again. [/quote]
11th Aug 2024 5:46pm |
No I've not found a supplier so its mainly just to visually confirm. Might see if I get chance later today. |
12th Aug 2024 6:38am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
I have my brake fluid replaced every MOT, F1 Autocentres do a deal for £45 to replace your brake fluid at the same time as the MOT.
12th Aug 2024 7:09am |
It's very likley that there is nothing wrong. Before you take it apart get under the dash to check for leakage out of the piston. If it's leaking here or somewhere else the brake fluid level will be dropping also so check this. If it's not leaking at the MC seals it's 'possible' the ABS is accumulating some fluid or needs purging. 2012 TDV8 Vogue (L322) |
12th Aug 2024 7:20am |
Hi All, Bit of an update!
14th Aug 2024 9:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8252 |
Glad it's sorted and a nice cheap fix... Pete
14th Aug 2024 10:36pm |
