![]() | Home > Technical (L322) > Brake pedal sinks to floor |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Hi Ian,
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
master cylinder. get it checked out soonest by a pro - you don't want to find problems when it goes wrong at 70mph. |
Ian_D Member Since: 07 Aug 2024 Location: Barnsley Posts: 8 ![]() ![]() |
Thanks both.
As well as the master cylinder I’d also be inclined to check all the brake pads, they tend to cause odd symptoms particularly if the have been overheated for any reason. |
my master cylinder was diagnosed by my indie LR expert. he said it is probably letting a little air in. He has over 20 years LR experience so I believe him. get a gen OEM if you can. |
Given it’s a fairly inexpensive job I think I’ll replace mine also. The fluid change definitely improved the feel but it’s still “soft” initially on start up. The actual braking is fine but for the sake of £200 I think it’s a good investment.
Mine needs doing as it keeps loosing vacuum overnight but the hydraulic system is fine so I have been putting it off. Not worth trying to save money on such a critical component so just go with OE. 2012 TDV8 Vogue (L322) |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 724 ![]() ![]() ![]() |
Some of you say you've had a brake fluid change, now when I've asked a couple of Indy's about doing it they suck in air through they teeth and moan about that's a right pita. Is this actually true? |
Yes it can be difficult as there is a procedure to purge the ABS via the GAP IID tool and the bleed screws have a habit of seizing in the front calipers requiring removal from the car and new threads cutting for larger bleed screws. 2012 TDV8 Vogue (L322) |
I assume the JLR SDD will have the options for purging the ABS? Still need to work out how to use it as its a bit OTT!
I honestly didn’t give it a thought, normally I use LR specialists but recently started using my local garage (who also operate a haulage business) and they didn’t complain about doing it. I doubt they have LR specific diagnostics so how it was done I don’t know. I still can’t make my mind up as to whether the MC is bad, the pedal is rock solid when the car is up and running - just the initial start up where it’s soft and tends to travel down slowly. If the MC was bad why do I only get the symptom that Ian gets on initial start up? Would a bad MC not be a little soft at other times? J |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
My Indy took a few attempts to bleed mine properly, and they had all the kit…..
You can easily bleed any replaced master cylinder without getting air into the abs block as follows.
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 416 ![]() ![]() ![]() |
the GAP tool makes bleeding a doddle.
