Home > In Car Electronics (L405) > Cannot get sound via maps on apple carplay
Johngrab
United Kingdom 2013 Range Rover Vogue SDV8 Fuji White
No you need to have your Bluetooth on and Wi-Fi for CarPlay to work but just make sure you don’t have it connected to your rr Bluetooth I had the same issue mate
Post #697473 6th Aug 2024 8:40am
Bluebird
Wales 2016 Range Rover Autobiography SDV8 Santorini Black
Thanks I will check this afternoon when free. On my iPhone in setting- then general I have car play- then it says Range Rover and Idcore. It also says set up CarPlay by pressing and hold the voice activation on the steering wheel.
Post #697474 6th Aug 2024 8:51am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
From what I see, the CarPlay functionality is made by Idcore, https://id-core.co.uk/
Best thing is to contact one of the Idcore distributors (there seem to be 2 in the UK) for help...
Post #697499 6th Aug 2024 4:42pm
Bluebird
Thanks mate I will. Tried taking off the RR Bluetooth but did not work, saying that I am useless with tech.😂
Post #697500 6th Aug 2024 5:07pm
Yeah, mine is connected to carplay and the original car BT and I get sound, I didn't when I bought it and it was one of those settings I mentioned at the start, I guess there are multiple reasons, mine is a lot better since I got a new carplay dongle, they obviously update them fairly often...
Good luck... Thumbs Up Pete
Post #697540 7th Aug 2024 8:37am
Bluebird
Thanks Pete, I checked the website they don’t give support for idcore as you need to go to the dealer you bought it from. As I did not buy it as it came with the car that’s the end of that. Not too worried as long as it has the navigation and works through CarPlay I can live without the sound. Might consider the car play dongle.
Post #697542 7th Aug 2024 8:49am
You have to be careful and get the right dongle, most are to convert wired carplay to wireless, not add carplay to an Android unit.... it's never easy and is the most expensive the best...?? probably not... Pete
Post #697546 7th Aug 2024 10:03am
Bluebird
Ok thanks
Post #697548 7th Aug 2024 10:49am
adara
I'm using navigation (Waze, Google & Apple Maps) on mute anyway...
Post #697549 7th Aug 2024 12:11pm
Bluebird
Yes I think that is the way to go, I was advised my audio specialist in Cardiff that it is a common issue with after market CarPlay. He offered to have a look at it , if I wanted to.
Post #697550 7th Aug 2024 12:17pm
