Home > In Car Electronics (L322) > 2007 Iphone integration
rory_mcw
I have used the search facility and TBH still no further forward. I have a 2007 VSE 4.2.
I would like to be able to fully integrate my iphone into the LR system, are there any people out there doing this modification? from what i read the LR one for my age of car is not a fully integrated system.......
i am happy to travel to have this done,
thanks in advance Rory
Post #69704 23rd Jun 2011 9:01am
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
You can get an updated bluetooth module from forum member Wiggs, it's £60 on an exchange basis. Note however that the module has a limit of 300 contacts. Is the integration you want for phone only or is it more Ipod functionality you want?
If it's the latter you just need a single jack lead to the aux input on the rear of the centre console, it doesn't give you ability to select tracks from the touchscreen, but you'll have ipod audio through the car speakers.
Hope this helps. 2012 SDV8 Vogue SE
Post #69705 23rd Jun 2011 9:05am
rory_mcw
i saw those aux input leads but im not a fan of that kind of thing, dont like cables etc poking out..........
i will PM wiggs, thanks very much for the help, Rory
Post #69706 23rd Jun 2011 9:08am
I use the AUX connection to play my iPhone through the sound system, and like you I'm not a fan of cables all over the place, but I'm reluctant to fork out the £400 or so it costs for the LR Ipod retrofit kit, so AUX cable it is until it really bursts my head enough to go for it! Wink
I got an exchange BT module from Wiggs, which did the trick. Once you make contact with him, he'll ship you the module within a couple of days (assuming he has stock), and it's an easy swap job.
Oh and who has more than 300 contacts in their phone? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #69728 23rd Jun 2011 11:04am
rory_mcw
the LR kit you talk about, is the one which only has 5 play lists and has a switch to change from cd changer to ipod? or is the £400 kit the all singing all dancing BT integration i am looking for? cheers Rory
Post #69736 23rd Jun 2011 12:03pm
2 separate things.
The LR Ipod adaptor lets you use the touchscreen and steering wheel buttons to control music on your device. It has no BT functionality, so the updated BT module allows the iPhone to connect and transfer contacts to the car and make phone calls. It doesn't play music. Might be best to imagine your iPhone as 2 discreet devices, an iPod which plays music (through the AUX input or LR adaptor) and a phone which uses the BT module.
cheers
Alan Got - 2017 SDV8 Autobiography in Loire Blue
Post #69738 23rd Jun 2011 12:27pm
Mine is a 2007 reg car but 2008MY, the BT will pull across contacts from my iphone 3GS.
I don't have the ipod kit, I have cables all over the place but it works ok. Discovery 4 HSE
Post #69748 23rd Jun 2011 1:21pm
rory_mcw
thanks very much alan, ok so 2 devices, right i have pm'd the guy regarding the BT module............ just waiting for a response, i will book my car into LR when i get home and the the module fitted to allow me to play music, unless i can buy it and fit it myself? cheers
Post #69771 23rd Jun 2011 5:09pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I believe I read on here that the iPod kit interferes with the bluetooth kit, so it may be worth some further investigation before you spend all that money.
Gone - Range Rover Supercharged 2006
Post #69791 23rd Jun 2011 9:38pm
JustinP
Found it,
http://www.fullfatrr.com/forum/topic257.ht...+bluetooth
Although other threads suggest LCM and Bluetooth work in harmony.
Post #69793 23rd Jun 2011 10:02pm
rory_mcw
thanks
the guy wiggs says he is no longer doing the bt module so back to the drawing board..............
Post #69883 24th Jun 2011 9:07pm
BRUNBERG
United Kingdom 2006 Range Rover Vogue SE Supercharged Bonatti Grey
Sorry to pull up an old thread but if I buy the iPhone cradle from the dealer and connect it to the adaptor in the arm rest will I be able to play music from my phone/ iPod using the touchscreen? 06 4.2 SC Bonatti Grey/ Ivory
Post #73726 25th Jul 2011 8:44pm
SteveMFr
Site Sponsor
The only dealer you can get an iPhone cradle from is BMW - and that only for the earlier console and with modifications.
The cradle also has nothing to do with the electronics to play music over the entertainment sys - it's just a nifty place to store (and with the right mods charge) your iPhone. You need the official LR AudioConnectivityModule to play music. And the BT module to make calls.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #73729 25th Jul 2011 8:57pm
BRUNBERG
Ah ok thank you, mine is an 06 but 07 MY. If I buy the audio connectivity module will I need to upgrade my existing Bluetooth also? 06 4.2 SC Bonatti Grey/ Ivory
Post #73730 25th Jul 2011 9:06pm
