Home > In Car Electronics (L405) > Dash clock time
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Dash clock time
Hi all,
Not the most drastic issue (especially for a RR) but does anyone else have a clock on the dash that keeps losing the correct time - I set mine quite frequently but it appears to get out of sync to the tuine of 2-3 minutes.... all the time....
All my previous cars stayed in sync and I think got the time signal from RDS..?
Anyone else had this or know of a solution?
Ta Muchly Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #696839 24th Jul 2024 8:31pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Yep, exactly the same issue. My car is a 2016my SDV8. Its annoying, but I have no solution!
Post #696843 24th Jul 2024 8:43pm
Tdtj
Scotland 2016 Range Rover Autobiography SDV8 Santorini Black
Yep same here. 2016 4.4 diesel
Post #696863 25th Jul 2024 10:19am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
There's a BCM update that addresses this problem.
I had this and updated the instrument cluster (only possible via SDD as Gap IID doesn't have the memnory capacity) thinking this would solve it and it didn't, I then discovered that it was related to the BCM. This can be done by Gap IID or SDD, kept perfect time ever since. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #696864 25th Jul 2024 10:47am
comports
ooh - Thanks 4RRS
How did you get hold of the update may I ask, or is it inbuilt into IID already?
I don't suppose you know if there is a wiki on how to perform the updates do you?
Thanks again..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #696869 25th Jul 2024 12:19pm
4RRS
You need to purchase it from GAP (follow the instructions on their website). Once downloaded to your tool its a straightforward process, however I would suggest having a decent battery support unit connected to your vehicle battery or 'jumped' to another vehicle while performing the upgrade.
If you have access to SDD, then it's free, but will definitely need battery support as it won't allow you to progress through the update stages until battery voltage is supported.
Hope this helps! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #696870 25th Jul 2024 12:29pm
