![]() | Home > Technical (L322) > Primary Turbo Location |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 199 ![]() ![]() ![]() |
Misread the question |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 40 ![]() ![]() ![]() |
The primary turbo is on the right hand side. Not sure that it’s the smaller of the two, it looks larger to me, but could be wrong. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3028 ![]() ![]() ![]() |
Right 2012 TDV8 Vogue (L322) |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 135 ![]() ![]() ![]() |
Is that looking at front or rear of the engine ? RR owner |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 11 ![]() ![]() ![]() |
Ok thanks guys. Yeah they don’t look any different in terms of casing size.
off-side 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2377 ![]() ![]() ![]() |
The primary turbo is the higher capacity of the 2, with the secondary only a fill-in for higher rpm. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 763 ![]() ![]() ![]() |
The primary is VGT and the secondary is Fixed
