![]() | Home > Technical (L322) > Primary Turbo Location |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
Misread the question |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 67 ![]() ![]() ![]() |
The primary turbo is on the right hand side. Not sure that it’s the smaller of the two, it looks larger to me, but could be wrong. |
Right 2012 TDV8 Vogue (L322) |
Old-un Member Since: 12 Feb 2022 Location: Manchester Posts: 150 ![]() ![]() ![]() |
Is that looking at front or rear of the engine ? RR owner |
CharlieF322 Member Since: 19 Mar 2024 Location: Essex Posts: 16 ![]() ![]() ![]() |
Ok thanks guys. Yeah they don’t look any different in terms of casing size.
off-side 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2584 ![]() ![]() ![]() |
The primary turbo is the higher capacity of the 2, with the secondary only a fill-in for higher rpm. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 892 ![]() ![]() ![]() |
The primary is VGT and the secondary is Fixed
Sql Member Since: 27 Jun 2015 Location: Poland Posts: 252 ![]() ![]() ![]() |
Did you ever manage to find out if this slight spool up noise is considered ok for this engine? Mine does that too. 12 4.4 TDV8 Vogue Nara Bronze / Arabica / Ivory / Piano 07 3.6 TDV8 Vogue Buckingham Blue / Sand / Piano |
